| Home > Help Needed / General Tech Chat > malpassi turbo pressure regulator | |||||||
32 Posts Member #: 10958 Member |
1st Oct, 2014 at 10:49:27am
Can anyone help? What sort of pressure is from the return outlet on the regulator feed back to the tank. I though it was at the charger pressure or does it just trickle back to the tank?
1st Oct, 2014 at 02:29:29pm
Depends on the output of the pump and demand of the engine.
In the 13's at last!.. Just |
1st Oct, 2014 at 06:45:10pm
On 1st Oct, 2014 HUBBA.HUBBA said:
Can anyone help? What sort of pressure is from the return outlet on the regulator feed back to the tank. I though it was at the charger pressure or does it just trickle back to the tank? And yes I know im stupid Cheers it should be under almost no pressure. But it will depend on the volume of fuel your flowing, and whether there are any other restrictions on the return line before it enters the tank 9.85 @ 145mph
