| Home > Help Needed / General Tech Chat > rear valance closing panel | |||||||
![]() 1751 Posts Member #: 10190 Post Whore belgium |
4th Oct, 2014 at 08:27:14pm
does anyone here have some dimensions of the rear closing panel on a van? need to make a new one but not sure about the height.
450 Posts Member #: 10396 Advanced Member Formerly mk2turbo Stoke-on-Trent |
5th Oct, 2014 at 07:06:15am
Is it the same panel on a pickup? The bit that closes the rear valance? Can measure for you later if it is. |
5th Oct, 2014 at 07:13:28am
I do think so. Most important for me is the height and where the hole's for cables go ( numberplate light) greets you can do anything if you set your mind to it...
976 Posts Member #: 3228 Post Whore North of the Netherlands |
5th Oct, 2014 at 07:20:23pm
Rammie, show me a picture of what you want measured and I'll do it straight away.
Dazed and Confused.... |
5th Oct, 2014 at 08:09:39pm
http://www.minispares.com/catalogues/class...r.aspx?3~23~155
5th Oct, 2014 at 08:25:53pm
Sorry Rammie couldn't get under the pickup today to have a look, will be able to tomorrow |
5th Oct, 2014 at 09:01:31pm
no problem. i have allot of welding to do on it on other places and have the turbo to feggel on so time is on my side... you can do anything if you set your mind to it...
7th Oct, 2014 at 07:26:30pm
As an extra... what is the tread size of the rear subframe bolts where they go into the backplate ( hope i explain this right...) of the nuts underneath the sill. you can do anything if you set your mind to it...
8th Oct, 2014 at 05:44:49am
I measured about 115mm height.
8th Oct, 2014 at 07:09:43am
I had a look at the pickup for you but that panel has been removed already as it needs restoring, sorry about that |
8th Oct, 2014 at 07:20:42am
No problems and thanks.
