Home > Help Needed / General Tech Chat > 12v feed for coil
1275grimsby
Member #: 10874
Grimsby
Hi all,
My problem is I have converted my spi to carb (turbo). The old coil feed was supplied by the ecu so I need to supply a new one.
My thinking is that if I take a feed from the fuse box, will this feed still produce 12v to the coil whist cranking as I noticed most things turn off when I turn the key to the crank position.
Is there a feed that stays live whilst cranking?
the haynes wiring diagram seem to go to the starter solenoid but im struggling to see where.
Is it a case of give it two feeds, one from the fuse box and one from the starter solenoid so one takes over from the other?
My coil is a 12v non ballast set up electronic ignition.
thanks
kyle
mine: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=570945
slater
Member #: 1291
Suffolk / Birmingham
Take it from the back of your ignition switch. You cant get any better than that!
I know on my metro of a similar age a lot of the switched lives cut out when its cranking presumably to save voltage drop.
1275grimsby
Member #: 10874
Grimsby
Will give that a go, thanks Slater
