| Home > Help Needed / General Tech Chat > HIF44E closed loop AFR anyone? | |||||||
3 Posts Member #: 10974 Junior Member |
12th Oct, 2014 at 12:06:26pm
Has anyone used a HIF44E with a wideband O2 sensor to control AFR?
12th Oct, 2014 at 12:25:43pm
Sounds like a nice idea in principal. If something is worth doing, it's worth doing half of. |
12th Oct, 2014 at 12:37:00pm
I was not running closed loop but i could use my ecu to control the effect of the lean off pipe at part throttle
Edited by Brett on 12th Oct, 2014. Yes i moved to the darkside |
12th Oct, 2014 at 12:46:16pm
Data logging rpm, manifold pressure, afr and the needle position is all the info you should need to profile the perfect needle
12th Oct, 2014 at 01:47:47pm
So you going to drive the electronic choke to adjust the mixture?
12th Oct, 2014 at 04:04:35pm
I think I've only ever seen one of these carbs many years ago and the stepper motor was to move the jet up and down for cold start enrichment (the "choke").
15th Oct, 2014 at 07:26:18pm
The choke in the HIF E functions in the same way as the HIF, but the choke spindle is turned by the stepper motor rather than by a cable. |
![]() 270 Posts Member #: 69 Senior Member Coventry |
16th Oct, 2014 at 09:00:19am
agree with Metro turbo I have at least one down the garage from a K series 1.1 metro |
16th Oct, 2014 at 10:51:39am
You can use a wideband for 2 distinctly different things: tuning, and closed loop feedback. With EFI, it's much much better to get the tune right, than rely heavily on feedback and the same principle applies to your carb idea.
Edited by PhilR on 16th Oct, 2014. |
976 Posts Member #: 3228 Post Whore North of the Netherlands |
16th Oct, 2014 at 12:23:45pm
On 16th Oct, 2014 PhilR said:
You can use a wideband for 2 distinctly different things: tuning, and closed loop feedback. With EFI, it's much much better to get the tune right, than rely heavily on feedback and the same principle applies to your carb idea. As Brett said, you really need to use the o2 sensor to help you profile the needle. Give it a perfectly profiled needle and this is the best your SU will be (and make sure it's in good health too). If you want simple, then try this: 1)wideband in the exhaust, gauge on the dash. 2)Some kind of indicator that shows the current height of the piston in the dashpot. 3)Video 1 and 2, then playback later and work out which needle stations need attention. Point 2 to is the trickiest. Driving around at wide open throttle with the bonnet off will probably draw a lot of attention. It would be better to somehow rig up a potentiometer to the piston and read the voltage from inside the car. Dazed and Confused.... |
16th Oct, 2014 at 12:31:26pm
Haha. I Knew it had been done before; no surprises it's on here! Nice one Brett. Edited by PhilR on 16th Oct, 2014. |
16th Oct, 2014 at 07:15:02pm
yeah it works well,
