Home > Help Needed / General Tech Chat > manifold vacuum for servo
rob620
Member #: 10537
alright guys :) just a quick question. Im half way through bolting all the turbo bits onto my engine and have just had a thought... where do I take a vacuum feed from for my brake servo?! When it was naturally aspirated i could understand the amout of vacuum in the inlet manifold but now its turbo'd surely the manifold will just be filled with boost pressure? What do people do to get round this? Thanks!
slater
Member #: 1291
Suffolk / Birmingham
You just need a one way valve in the line.
rob620
Member #: 10537
So I take it then the servo will only really work when off boost or coming of boost? its got me abit stumped lol
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
brake boosters should hold enugh vacume to do a few pedle pushed
if the car is switched off from running then you should beable to press the pedle a few times as it graduly runs out of sorted vacume and the pedle becomes hard to press
Get rid of the servo. They are for girls.
rob620
Member #: 10537
Can anyone tell me where I can get one of the correct one way valves from? I did see one mini spares they list an in line filter which stops fuel contamination in the servo. Would that be the one? Or do I need something different? Thanks
You should have one on your existing hard plastic line (if you have one)
rob620
Member #: 10537
Thanks carlzilla, I have the hard plastic line so will check when I get home :) I pressume there isnt any difference between the ones fitted to n/a or turbo engines? Thanks
Don't think so, It should work just as it is, the one way valve is the important part.
lol
