| Home > General Chat > Alternator pulleys. | |||||||
14th Oct, 2014 at 06:15:10pm
Well, shauna bought a new 70a alternator from minispares and it's done nothing but squeal like a pig, I've tightened it up a few times thinking its come loose but still kept doing it. My old 70a one which I've thrown on hasn't slipped at all. The difference is the pulley, my old 70a and every other usual alternator I've seen has a pressed pulley that tapers down to nothing, the one supplied on the minispares alternator is wider then the other and it also has a flat bottom and it's a load of shit. Has anyone else used one?. I'll let the picture do the talking....
Edited by Carlzilla on 14th Oct, 2014. On 26th Jan, 2012 Tom Fenton said:
![]() 2975 Posts Member #: 10749 Post Whore lowestoft suffolk |
14th Oct, 2014 at 06:26:09pm
Hmm that is odd, never realised any differrnce before On 24th Oct, 2015 jonny f said:
Nothing gets past Dave lol NOTHING GETS PAST ME!!
1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
14th Oct, 2014 at 08:53:08pm
fatter belt or swap pullys?
Yes i moved to the darkside |
14th Oct, 2014 at 09:02:23pm
time for a new belt |
15th Oct, 2014 at 11:04:28am
IIRC from a past life, as well as Vee belts coming in different widths there are at least two different height (or thickness) profiles so for the same width at the top (outer circumference) the inner circumference sits lower or higher in the pulley groove.
![]() 1043 Posts Member #: 10424 Post Whore Swansea boyo! |
15th Oct, 2014 at 12:27:30pm
Personally I think you should just keep it for yours and I'll buy a belt to suit They don't die, they just get faster! |
![]() 690 Posts Member #: 1851 Post Whore Woolavington, Zummerzet |
15th Oct, 2014 at 10:23:08pm
I'm glad it's not just me !!
Metric is for people who can't do fractions. |
16th Oct, 2014 at 07:28:57am
Stabbed in the spuds? I would do more than squeal.... I run a supercharger and I don't care the TB is on the wrong side.
18th Jan, 2015 at 11:17:32am
Alex, did you have any luck with swapping belts?
