| Home > Help Needed / General Tech Chat > DIY turbo rebuild | |||||||
![]() 265 Posts Member #: 68 Senior Member Coventry |
16th Jan, 2004 at 06:54:15pm
Right, ive 90% stripped the T3 but im a bit stuck now as to what to do next. the exhaust turbine dont want to come off the shaft. any ideas? all that im left with, is the centre casting (which the oil feed though, and the exhaust turbine, with that cup shaped thing in between. there seems to be some funny triangular rounded angular funny shaped thing on the exhaust turbine end, but doesnt seem to want to turn. is this a nut? Sooperdooperturbocooperexpertengineering! |
16th Jan, 2004 at 09:42:08pm
you dont need to remove the eehaust turbine because once youve removed the compressor wheel, the shaft should just pull out with the exhaust turbine on the end from what i can remeber. if youve not removed the nut on the compressor wheel side hold the triangle nut on the exhaust bit(i fink a 14mm 6 sided socket does the job) and undo the little nut on the compressor wheel.
Edited by Carl on 17th Jan, 2004. no longer a series, but still 1.3 turbo.
16th Jan, 2004 at 10:35:59pm
The exh turbine does NOT come off the shaft, its friction welded on there!!! The triangle on the end is used for balancing the assembly, so any damage might effect the dynamic balance badly!
AlexF |
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
17th Jan, 2004 at 07:48:25pm
Got to admit i dont think i'd ever try rebuilding my own turbo. It must affect the balance by a huge amount. Also depends how bad the turbo was in the first place, was the compressor or turbine rubbing any of thre housings ??? |
19th Jan, 2004 at 06:43:33pm
Right, the compressor wheel is off, the shaft that end is bare, ive removed the bearing circlip, so the exhaust turbune and shaft should juts pull though yeh? havent been forcing anything, so hadnt really tried that. been real gentle with it.
19th Jan, 2004 at 10:04:51pm
it should just pull through...
AlexF |
20th Jan, 2004 at 07:31:59pm
see above post,
20th Jan, 2004 at 09:43:02pm
good good
AlexF |
![]() 384 Posts Member #: 4215 Senior Member |
12th May, 2012 at 06:15:46pm
i know this is an old post, but thought why start a new one...
12th May, 2012 at 06:32:34pm
The "stupid triangular nut" at the other end isn't a nut, well not on the T3s anyway.
12th May, 2012 at 07:40:40pm
Full marks for searching an old thread.
In the 13's at last!.. Just |
12th May, 2012 at 08:05:44pm
theoneeyeddizaed: i did read the whole thread, and know the triangle "nut" is not an actual nut. what i ment was the best way to hold the triangular thing to keep it from spining. but took the advice above and used a sixpoint socket which worked a treat and got it undone already.
Edited by c2_mad on 12th May, 2012. |
12th May, 2012 at 08:29:15pm
Whatever you do dont use a hammer !
12th May, 2012 at 09:19:55pm
got a puller on there and finally got it moved...
12th May, 2012 at 10:10:16pm
On 12th May, 2012 c2_mad said:
got a puller on there and finally got it moved... If you used a puller it will be bent.... Sorry, but it will be, they are very thin aluminium. Just press the turbine shaft backwards next time and NEVER use a hammer on something as small and finely balanced as this.... Schrödinger's cat - so which one am I ??? |
12th May, 2012 at 10:23:49pm
for a stuborn impellor, application of a little heat will allow the impellor to just lift off. On 26th Oct, 2004 TurboDave16v said:
12th May, 2012 at 11:28:46pm
i used a small puller hooked on the backplate to push the shaft out towards the turbine end,as suggested by kean on his guide to rebuilding the turbo i dont see what could be bent, the shaft? did you maybe think i hooked the puller to the compressor wheel itself and bent that??
![]() 825 Posts Member #: 2208 Post Whore Essex |
13th May, 2012 at 04:02:49am
there was a step by step guide i used from another forum, sure they do one for the t2 as well.
