| Home > General Chat > prices | |||||||
![]() 131 Posts Member #: 10521 Advanced Member Aberdeen |
17th Oct, 2014 at 11:59:43am
I've decided i'm going back to a c20xe. So wanting these parts sold what are they worth before I put them up for sale??
Flat oot like a dukes fit! |
17th Oct, 2014 at 12:18:00pm
On 17th Oct, 2014 Baz_rsp said:
what are they worth before I put them up for sale?? Gearbox has been rebuilt with all new bearings, baulk rings and a set of s/cut clubman gears from mini spares. This also has new cross pin diff. Bottom end; •+0.020" bore to 1293 with centre main strap by Morpseed •AE21253 pistons with dish increased to give 13cc by morspeed •Avonbar Phase 2 turbo cam •avonbar high flow oil pump •ARP rod bolts •reground and balanced crank with new acl bearings. •kent cams vernier timing chain set Matty manifold for a gt1752 s/cut drops. With extra gear. They are all worth whatever they are worth to someone else. Simple fact of life, is that they aren't worth what you paid, or perhaps overpaid for them in the first place. Here are some simple guidelines: If you get offered 75% of the value of same or comparative new product, you should make the deal. If you get offered 50% of the value of same or comparative new product, you may, or may not want to If you get offered 25% of the value of same or comparative new product, you should not make the deal as someone else will likely offer more. Eventually. On 17th Nov, 2014 Tom Fenton said:
17th Oct, 2014 at 12:21:22pm
My take:-
17th Oct, 2014 at 12:31:04pm
Think It would be worth splitting the short motor??
17th Oct, 2014 at 12:32:09pm
Be interested in short block. IE, block, crank, rods and pistons. |
17th Oct, 2014 at 12:37:09pm
pm replied to jonny
