| Home > General Chat > Supercharged BINI misfire | |||||||
17th Oct, 2014 at 10:08:48pm
Gents
17th Oct, 2014 at 10:37:14pm
Just been reviewing the bini forums. Its hard to get some good advice.
17th Oct, 2014 at 11:07:27pm
tom you say the coil terminal was corroded, did you just sort the terminal or change the coil ? if you didnt change the coil i would.
17th Oct, 2014 at 11:47:15pm
Im tired of working on my dads it ended up going home from mitp on a recovery truck with a seized coolant fan and coolant temps at 140 before it died the expansion tank cap swelled up like a baloon and it melted 2 plugs
Yes i moved to the darkside |
18th Oct, 2014 at 06:15:45am
My sisters n/a 1.6 one strangely had a small piece of valve missing abd it developed a small misfire which i myself thought was electrical etc, took it to a mate thinking head gasket and turned out to be the valve was a goner, worth doing a compression test if you haven't done so already to rule it out. On 26th Jan, 2012 Tom Fenton said:
18th Oct, 2014 at 11:29:59am
carbon buildup is on the turbocharged direct injection engines as the inlet valves dont get washed with fuel. they also suffer from high, and low pressure fuel pump issues and breather issues all of which cause odd missfires. Tbo all of the supercharged ones i used to look after were generally pretty stout. i'd defo do a compression test, then it'd be fuel pressure. turbo 16v k-series 11.9@118.9 :)
19th Oct, 2014 at 07:23:23pm
Tom have you had a leak down test done on the engine? that will tell you if you have any issues within the engine
19th Oct, 2014 at 07:28:02pm
Gents
19th Oct, 2014 at 08:20:36pm
Tom
20th Nov, 2014 at 10:07:42pm
Ok to finalise this.
20th Nov, 2014 at 10:21:53pm
Seems such a common issue these days with faulty new parts |
20th Nov, 2014 at 11:36:36pm
Fuel filter is always a good one to so it's jot long life as bmw claims and I did coil pack last night on my mates her misfire has gone now aswell you use a genuine one |
21st Nov, 2014 at 08:26:42am
No not a genuine one, but why should I have to? An aftermarket part has to be fit for purpose. There is nothing special about the OE coilpack, after all it is nothing more than lots of copper wire.
21st Nov, 2014 at 02:21:32pm
my clio had a misfire for ages, turned out it was incorrect spec plugs from manufacture, so as soon as I was coming on boost it would miss. its happening more and more with genuine new parts been in the wrong box etc, did a f30 bmw box said 300mm disc's inside the genuine bmw box were 325mm disc's. could have been something like this
23rd Nov, 2014 at 07:19:35pm
Hay mate, if you can't sort it it's worth speaking to the masters at 1320Mini http://www.1320.co.uk/ what they don't know about them isn't worth knowing :) Best 1/4 mile 13.2 seconds @116 mph
23rd Nov, 2014 at 09:56:46pm
On 21st Nov, 2014 Tom Fenton said:
No not a genuine one, but why should I have to? An aftermarket part has to be fit for purpose. There is nothing special about the OE coilpack, after all it is nothing more than lots of copper wire. |
