Home > Help Needed / General Tech Chat > Line boring advice needed
PhilR
Member #: 10034
Birmingham
Engine had 100k miles on it, and the main bearings failed due to high revs, bad lubrication (oil too hot) and and a cluch that was out of balance (one of the verto spring fingers had snapped off and was rattling around inside). Front and centre main straps are "ok"; back strap is a slightly tight fit when the alignment dowels are in place, and had a black, scorched look to the surface when dismantled.
I had engine shop line hone the main bearings in the hope they could recover it, but they've properly f**ked it up - The rear-most strap has been sanded down badly(it doesn't sit flat), and they didn't insert the alignment dowels for any of the straps when they honed it (WTF *angry*).
I've only managed to find one place that does line boring (Coventry Boring & Metalling Co.) and they suggested it would be arround £200 + VAT, so does anyone know if I can get it done for less (where?) or should I just get a new block.
Ideas please. HELP !
Mike-998
Member #: 9774
Buckinghamshire
Can't comment on the cost of line boring but Coventry Boring and Metalling were the cheapest I found for other engine work, I had them fit a liner and bore the block and they did a good job of that.
I think MED can do it?
line bores/hones always seem to be pricey, 200 sounds in the right ball bark
philc
Member #: 1346
bromsgrove
Try mja engineering in bromsgrove martin can do most things
Drop me a PM i have a guy i use who you could try.
Does it matter what it costs? Surely the halfwhit that fucked it up will be paying to sort it out.
1380rich
Member #: 9766
Warwickshire
Southam mini and metro centre 01926 815681 they sorted mine. I know they were really cautious who they used
Avon 2010 class c 3rd
mossy2a
Member #: 9751
Derbyshire
I used service garage in ockbrook derby, although I had new pistons they wanted everyone so they could match the tolerance on each bore to each piston. I only paid £120 also. I was very impressed.
Id get a new block. Especially as your in a worse place then before you started.
My machinist uses a place in St Helens for line boring. Made a good job of mine. Look at MED or Swiftune as it might be worth the little extra for a full set of steel caps along with the line bore
Are you serious about the cap being "sanded" down and the sleeve dowels not being fitted ?
If so I would name and shame loudly.
If the bores of the block/caps have gone oversize or oval on any engine the repair needs to be taken seriously.
Done properly the caps would be milled (flat) and fitted with the sleeve dowels to give an undersize hole for line boring/honing.
But it adds lot off issues, especially on the Mini as it inevitably moves the crank centreline up in the block.
Not too bad on a conventional engine but puts the primary gear out of centre in the oil seal and, more importantly IMO, reduces the engagement with the idler gear.
If it's for high performance, I would look for another block.
This is true, but easily managed.
I can recommend Coventry boring, we use them for most of our boring at work. Paynes near Oxford is another place, but they seem a bit hit or miss on quality.
The only way I can see to recover it is to measure the centre line of the caps and block, and work out how far off centre line they have bored it, or if its on centre line. If it is biased the caps (which sounds like it could be) then you may get away with another set of caps (good time to fit cast 4 bolt centre main). Skim the new caps, then line hone. A good line honing company should be able to pick up the bore and only take say half a thou out of the crankcase so won't effect any other dimensions on engine.
We quite often have to recover crank cases that have been repaired/welded and line honed back inline. It can be a pain..especially scraping in bearing caps. *oh well*
Edited by matty on 20th Oct, 2014.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
having been a sucker to a bad shop myself i feel your frustration man
best advice i can give is use a guy that is known for doing good work by peoples say that you know well
as said above
PhilR
Member #: 10034
Birmingham
Two of the caps have a surface finish similar to the mating face on the block, machining line running in-line with the crank; The end cap now has sanding marks running perpendicular to the crank, maybe 120 -240 grit. When torqued down, there is clearly daylight showing through the end facing the crank tail.
When I picked up the block, the 6 dowels were still threaded onto the tie-wrap, just I'd given them. Assembling the block a month later, shows sight rub marks on the sides of the centre and front bearings and the rear bearing just locked up.
The straps were borderline when I gave them the block, so for £30 I asked them to see if they could hone them back into shape before putting any time / money into the block. I was anticipating that it may need boring, but I'd like to think that someone with their wits about them could have saved it.
The mistake is done now, I've got way too much going on right now to turn this into a drama; I just need to get this fixed be someone who knows what they're doing so I can get this fixed this side of winter.
Thanks for the suggestions so far, keep them coming if you've got any ideas. I'm going to continue phoning around tomorrow.
PhilR
Member #: 10034
Birmingham
Apart from skimming, can they build them back up with weld, or bore them oversize and fill them with spacers? - Need to know what options there are so I'm not put on the spot and make the wrong decision if options are offered
Edited by PhilR on 20th Oct, 2014.
Find another block.....
Too be honest not much can be done that'll be cheaper than starting again with another block. Especially in a hurry. The main thing that needs to be determined is how much has been bored out of the block side, and if its still been bored on centreline of caps.
I'm happy to have a look for you, but you are a bit far from me really.
tadge44
Member #: 2500
Buckinghamshire
Don,t mess around any more just get another block - it should be cheaper than paying to (maybe) fix yours.
Re. the "sanding" marks, if they are perpendicular and dead straight, it's possible they put the cap on a surface grinder with a badly dressed wheel rather than milling it (the wheel would have to be in very poor condition though for the depth of marking you suggest).
Re. the daylight, try torquing it down without the sleeve dowels, they may have taken too much off the cap face and the dowels are bottoming out in their holes (a long shot as, from memory, the clearance on the end of the sleeves is quite large).
EDIT - typo
Edited by Rod S on 21st Oct, 2014.
PhilR
Member #: 10034
Birmingham
Thanks for the suggestions all, I'm putting it away until next year and going to build up one of my 998 blocks
skolawn
Member #: 69
Coventry
coventry metalling and boring have an excellent reputation and I have used them 30 years, southam dont do line boring nor do MED.
