| Home > General Chat > 12g940 head modifying for n/a use | |||||||
24th Oct, 2014 at 04:42:27pm
I have in my possession a 12g940 from an a series engine, and a 12g940 from a late carb engine with unleaded inserts.
![]() 207 Posts Member #: 9045 Senior Member Wolverhampton, West Midlands |
24th Oct, 2014 at 05:02:49pm
I'm running 35.7x29 in mine with a 276, the valve seats get recut for bigger valves anyway so new inserts would be fitted regardless?
24th Oct, 2014 at 05:14:57pm
I'm not really sure what the crack is with inserts, don't know whether you can cut them bigger, where to get inserts from if needed as minispares only list std sizes i think, just a grey area for me that hopefully someone will be able to clear up! On 26th Jan, 2012 Tom Fenton said:
24th Oct, 2014 at 06:43:19pm
I've got 30mm valves in my unleaded inserts. If something is worth doing, it's worth doing half of. |
24th Oct, 2014 at 06:45:08pm
I guess yours is 33 x 29mm. MG metro heads were 36 x 29mm which seems to be a fairly sensible upgrade (for NA at least). That would mean larger inlets, but it's only the exhausts that need hardened seats to exposure to the exhaust gasses. If you only increased the exhausts size to within the edge of the hardened seat, I don't think it would need to be changed, just cut larger.
Edited by PhilR on 24th Oct, 2014. |
24th Oct, 2014 at 07:01:06pm
Well im not sure of the cost, but the guy who does all my machine work is very reasonable on cost (crank regrind and 4 hones cost £90) But if you wanted to just do a small size increase, there are some tools you can buy to do the job: http://m.ebay.co.uk/sch/i.html?_nkw=valve+...lve+seat+cutter Edited by Carlzilla on 24th Oct, 2014. On 26th Jan, 2012 Tom Fenton said:
24th Oct, 2014 at 08:37:39pm
A good basis of a fast road home brew head would be to use the later unleaded casting, use the standard 29.4mm exhaust size but enlarge the inlet valve to the early NA MG Metro size (35.7mm)
510 Posts Member #: 1592 Smart Guy! mainland europe near ze germans |
25th Oct, 2014 at 10:56:23am
what Phil sais.
Edited by Sir Yun on 25th Oct, 2014. That sir, is not rust, it is the progressive mass reduction system
29th Oct, 2014 at 06:28:11pm
First of all, The 276 does not like 1.5 rockers apparently.
