Home > Beginners Tech > carb to inlet doesn't match
You can buy spacers, theyre normally that black nylonny plastic stuff
I would go with anything you have to hand thats the correct thickness
Or if i was buying ( taking into account getting mini parts to belgium may not be easy) aluminium, i like working with aluminium
Rammie2000
Member #: 10190
belgium
the biggest i can find is 14 mm and i need 17... but i have a mate that can make them. ( at least he says so) maybe a good idea to have 2 vacuum connections build in to it? bit like the one in the link.
