| Home > General Chat > low oil pressure, cooling jets and other thoughts | |||||||
27th Oct, 2014 at 09:21:23am
OK, as you will know, the gearbox let go which has given me the opportunity to pull the engine apart and investigate other matters.
27th Oct, 2014 at 09:41:14am
i think heat may have killed the spring inthe jet allowing it to open at a lower pressure,
27th Oct, 2014 at 10:06:49am
photos of the Pump;
27th Oct, 2014 at 10:08:34am
if the threads and holes are not spot on you will likely need a soft material to crush seal or similar
27th Oct, 2014 at 10:09:30am
that pumps fucked lol but yes bwm jets are the way imo |
27th Oct, 2014 at 10:26:04am
I'd be tempted to just block the jets off Rob. If something is worth doing, it's worth doing half of. |
27th Oct, 2014 at 10:43:54am
why so John? I'm running standard pistons and want to give it as much as I can. |
27th Oct, 2014 at 12:02:18pm
In your position Rob I would not hesitate -BMW jets, sealed to the block and a new high capacity oil pump.
27th Oct, 2014 at 12:17:35pm
Andy & I didn't manage to melt standard turbo pistons on the van at over 20psi. If something is worth doing, it's worth doing half of. |
27th Oct, 2014 at 12:30:16pm
Yes, going to change shells anyway. Just been quoted £18/ jet though which is a bit pricey?
On 27th Oct, 2014 tadge44 said:
In your position Rob I would not hesitate -BMW jets, sealed to the block and a new high capacity oil pump. I assume you will change all the bearings too ? |
27th Oct, 2014 at 12:39:21pm
That's what mine were from BMW. |
27th Oct, 2014 at 12:40:01pm
However! If I were to run jets they would be BMW. I have a block machined for Zetec ones and I think I would change it to run BMW one's still! If something is worth doing, it's worth doing half of. |
27th Oct, 2014 at 01:41:16pm
should have more than enough flow with a hc oil pump for decent pressure and to run oil jets... |
27th Oct, 2014 at 04:03:27pm
I don't see the problem 20psi at idle when hot is pretty normal. |
27th Oct, 2014 at 04:08:04pm
The idle pressure wasn't so worrying as the pressure under load |
27th Oct, 2014 at 04:51:05pm
Its all pretty normal. Id not be worrying anyway. Than again while its apart you may aswell replace and suspect bits |
27th Oct, 2014 at 06:11:12pm
the pump looks gererally shit quality to me,
![]() 6965 Posts Member #: 507 Fastest A Series Mini in the World leeds/wakefield. |
27th Oct, 2014 at 06:11:53pm
the pump is buggered rob and is the main culprit to low pressure surely,
27th Oct, 2014 at 08:47:52pm
I ruined the springs inside the zetec jets when I applied heat, for a reason I cannot quite remember. at that time I removed the little check valves altogether and ran with the large gaping holes that are the zetec jet nozzels. Oil pressure was very poor at idle but picked up when the revs did, but not hugely above 40 psi. It was relatively ok through two 2 hour dyno sessions and a dyno shoot out for Mini Mag, after which the engine was pulled and BMW jets retro fitted. The bearings all went back in as there was no damage to them.
27th Oct, 2014 at 08:54:49pm
fwiw most of the undercrown jets i have removed from oe engines have no sealing as such, its just a banjo and relatively flat surfaces, no sealing washers. infact most manufacturers who use camshaft spray bars also lack sealing washers on there feed, which is usually a banjo. Dont really feel its an "issue" but i guess sealing washers cant do an harm. turbo 16v k-series 11.9@118.9 :)
28th Oct, 2014 at 03:58:26am
Did you measure the end-clearance on the pump? that is where you lose pressure, not on a worn outer diameter (or inner diameter of the housing)... On 17th Nov, 2014 Tom Fenton said:
28th Oct, 2014 at 08:59:38am
I didn't Dave to be honest. I was more interested in the fact i needed a shifter to actually turn it |
1st Nov, 2014 at 09:02:42am
Has anyone tested the zetec jets before? I thought it would be fairly easy to rig something up and see if mine were actually working (well the valve anyway) |
1st Nov, 2014 at 10:57:10am
Not sure of the design of the Zetecs, but for mine, with the jets removed, I just used rubber tube and a foot pump. All 4 jets opened/ held at 30psi. |
1st Nov, 2014 at 01:08:35pm
That was my thinking |
