Home > Help Needed / General Tech Chat > Fuel return
franky4x4
Member #: 10948
swansea. south wales
I am in the middle of sorting out the fuel system on the van. my question is this. the tank is the original van tank obviously I have to add a return line from my swirl pot,?can I just drill and tap a hole and screw in a normal 8mm barbbed brass Union or will I need a sealing washer of some discription. I'm unsure whether it will leek vapour. Or the tank needs to breath. Is this done through the fuel cap itself? Sorry for being vauge or not discribing myself very well. (But I know what I mean in my head lol)
Your here for a good time! Not a long time!
http://s1347.photobucket.com/user/franky4x44/library/
I just plumbed mine into the filler neck with a barbed return. Worked fine.
franky4x4
Member #: 10948
Yea iv heard of that route before but can visualise it do u happen to have a pic of it I know it's a long shot lol
Well actually mine was in a kit car using a van tank. access was easy, not sure if it's as simple on an actual van.
I'd want a more permanent and sealed pipe if returning to the main body of the tank.
Rammie2000
Member #: 10190
belgium
I seen one who had cut the neck in 2 and added a silicone tube with a small t piece on it. Not for turbo use but for injection. Works very well.
wolfie29177
Member #: 476
The Black Countraaaaay
you could always do what you suggest and then seal it with chemical metal to ensure it's completely sealed
Masturbation is not a crime its a hobby
franky4x4
Member #: 10948
Cheers guys think I will go with drill and tapping it. Plus chemical metal to ensure its seals! Good shout Wolfe!
