Home > General Chat > Weber DCOE and MJ Tuning
Craigie-B
Member #: 9468
Wootton Bassett
Hey guys!
Finally got the car running (sort of) today and I think it needs a proper tune up - seems to be running really lean and won't idle properly and back fires through the carb (sometimes I get smoke from one of the sides.
Do you guys know of anyone who is really good for tuning webers and also for mapping MJ in the South West? I am based in Royal Wootton Bassett (Basically Swindon)
Cheers :)
Craig
Edit: I think I pressed the poll by accident sorry!
Edited by Craigie-B on 1st Nov, 2014.
DILLIGAF
Member #: 9128
Don't know anyone down there, but have you got the mixture screws adjusted correctly. If your weber has the air bypass circuit (white plastic covers on the adjusting screws), You need to turn 'em out four and half turns (starting point) instead of the two and half turns of the earlier dcoe's (no air bypass circuit).
Edited by DILLIGAF on 1st Nov, 2014.
Craigie-B
Member #: 9468
Wootton Bassett
let me get a picture for you my friend, this is the first weber I have owned and I am new to carbs anyway :)
Before I re-build it:
After:
There is only springs underneath the idle mixture screws
Mike-998
Member #: 9774
Buckinghamshire
Would Neil Slark not be the man to see? Must do webbers for the race cars and I know he does MJ
Craigie-B
Member #: 9468
Wootton Bassett
Yeah I went and saw neil for the turbo - I don't know if he does webbers or not though
DILLIGAF
Member #: 9128
No thats a earlier weber without the bypass circuit. Just watched your vids on That other forum and it sounds like it's running on 3. Check and adjust your tappets, if you've got a spark on all four plugs.
Craigie-B
Member #: 9468
Wootton Bassett
Okay I will do, I know I was getting a spark at the ht lead end on all leads but haven't checked the plugs. Will adjust the rockers again just to be sure :)
nick1275
Member #: 1615
Ferndown, Dorset
neil does webbers, he did mine.
On 1st Mar, 2009 MikeRace said:
Hmmm weberyyy
On 21st Apr, 2009 madcatminis said:
I hope she's got knickers on or you'll have a funny runny mark on your bonnet. Quite like what a snail leaves behind.
Craigie-B
Member #: 9468
Wootton Bassett
Epic what spec do you have did it take more than a day??
nick1275
Member #: 1615
Ferndown, Dorset
usual 1380, dizzy etc. only took him couple of hours at most I seem to remember
Hmmm weberyyy
