| Home > Help Needed / General Tech Chat > Carb to supercharger pipe | |||||||
95 Posts Member #: 10924 Advanced Member Wroclaw/Poland |
4th Nov, 2014 at 10:23:04pm
Hi
Edited by SadamPl on 4th Nov, 2014. Made in Poland build thread:
![]() 2975 Posts Member #: 10749 Post Whore lowestoft suffolk |
4th Nov, 2014 at 11:54:22pm
Might aswell make a bigger better pipe whilst your at it... On 24th Oct, 2015 jonny f said:
Nothing gets past Dave lol NOTHING GETS PAST ME!!
1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
5th Nov, 2014 at 12:05:30am
If you want use silicone, because you're running 'suck through' you will need Fluoro Silicone, to withstand the fuel. I looked at this as I needed a 90 bend very close to the injector, but I couldn't find any large enough as they tend to be made for fuel / oil / liquids |
5th Nov, 2014 at 07:57:35am
It may seem odd that the link pipe is a smaller diameter than the carb, but I'd be tempted to leave it as it is. These long pipes between carb and SC are a bit crap. You need to keep the air speed up in them as they are prone to fuel pooling and poor idle. This may be a restriction at higher rpm, but otherwise your idle will have to be really high. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
![]() 553 Posts Member #: 1356 Post Whore TRURO, CORNWALL |
5th Nov, 2014 at 08:07:15am
I asked stuart gurr about this at vmaxscart, he said the link pipe diameter is correct |
5th Nov, 2014 at 08:12:11am
Be interesting to see of it made any difference. I doubt it would. Wouldnt bother changing the SC flange end, I don't see any real gain there. If you keep the small pipe just make sure there's a smooth transition between carb and pipe bores and maybe fettle the SC itself to remove the lump that overhangs the pipe if poss. Edited by slater on 5th Nov, 2014. |
976 Posts Member #: 3228 Post Whore North of the Netherlands |
5th Nov, 2014 at 08:20:20am
You might want to consider heating the pipe, I have read to many stories about carb freezing.
Dazed and Confused.... |
5th Nov, 2014 at 12:45:08pm
You mentioned all of the things I was thinking about.
20th Nov, 2014 at 07:11:21pm
I finally decide to do some work on the carb-sc piping, still in progress, but here is what I've got:
133 Posts Member #: 476 Advanced Member The Black Countraaaaay |
21st Nov, 2014 at 10:46:09am
personally I'd want the carb as close to the supercharger as possible and with a pipe with a slightly rough surface for a few reasons. Long pipe equals loss of velocity and as someone else said there's a risk off fuel puddling due to that plus a smooth pipe. Your other option is replacing the carb with a throttle body and MS system Masturbation is not a crime its a hobby |
21st Nov, 2014 at 07:52:06pm
I am limited by a few factors here. Space under the bonnet is one of them, there is no way I could squeez the carb closer to SC and at least with this setup it should get some cold air from the grill.
18th Mar, 2015 at 10:34:01am
So the car is running. Pretty nice actually so I'm happy with that. But there are some additional issues. One of them is connected yet again with carb - SC link pipe.
18th Mar, 2015 at 05:20:25pm
The only solution I can see is running a smaller diameter pipe to try and keep velocity up and stop the fuel dropping out. Unfortunately this is the downside of these setups. You either need the carb closer to the blower or injection they are very flawed |
18th Mar, 2015 at 05:46:58pm
wrap the pipe in copper pipe and run coolant through it so its nice and toasty and the fuel evaporates turbo 16v k-series 11.9@118.9 :)
18th Mar, 2015 at 06:48:45pm
That's a good call too actually. Heat the pipe like you would a manifold. |
18th Mar, 2015 at 08:03:52pm
Have a look at grahamxx thread on tmf he made his own kit and used a double walled inlet so he could run a heater manifold the same as mentioned above I run a supercharger and I don't care the TB is on the wrong side.
18th Mar, 2015 at 10:01:51pm
Thanks for the tips. I'll have a look at the car again tomorrow and I'll try to come up with a setup that will be compact enough to squeez it in with a servo.
19th Mar, 2015 at 12:34:04pm
I went for a drive again to check how soon the pipe will absorb the heat from the engine got it to temp. and then cruised around for a few minutes, engine in normal working temp. and pipe still ice cold. It is less than 10 degrees outside today, so I guess it'll be a bit better in the summer but still I need to address that.
![]() 7 Posts Member #: 7425 Junior Member |
24th Mar, 2015 at 09:52:32am
I have a VMAXSCART kit on my mini and it has taken quite a while to get it running well.
24th Mar, 2015 at 10:51:39pm
Great pics, thanks.
![]() 324 Posts Member #: 9441 Senior Member South Devon |
24th Mar, 2015 at 11:21:19pm
We had a supercharged Mini in at work a few years back that had the long style that suffered from icing.
