Home > Help Needed / General Tech Chat > oil dump question.
Rammie2000
Member #: 10190
belgium
I am looking into what way i should go with the oil dulp. Option one or 2?
On this second pic i would lead it to a splitter of the oil filter. ( at least that is what i thinck it is)
oli79
Member #: 8480
That in the second pic I think is a oil to water cooler, std metty turbo fitment a believe and maybe best off in the bin(others may have more idea with that) If you try to dump oil into either of those 2 pipes on the side, all that will happen is the oil will fall out the other one onto the floor, not into the sump/gearbox as intended
I cant see and issue with drain 1
Edited by oli79 on 4th Nov, 2014.
On 5th Oct, 2014 Shauna said:
The Morris Ital assassin!
Rammie2000
Member #: 10190
belgium
right now you mention that i did hear something like that. the first option is only a slope off about 6 cm over a length of a good 35 cm
D4VE
Member #: 10749
lowestoft suffolk
Option 1 into dizzy 'ole!! Thats where i do my dumping! *smiley*
Nothing gets past Dave lol
PhilR
Member #: 10034
Birmingham
Distributor hole looks good. It can't flow back into the filter as that's under pressure.
why not into the top of the transfer housing? quieten down the drop gears a little too?
Rammie2000
Member #: 10190
belgium
Hm. Yeah. But how do i do that? Drilling a whole behind the air breader. then just bolt a tube conector to it?
Drill a hole anywhere in the transfer cover that's suitable.
Either drill/tap a fitting or weld a tube into the housing.
It's actually a pretty good idea
Second pic is a liquid to liquid heat exchanger type oil cooler as fitted to N/A MG Metro. They should be good in theory but in practice Andy & I found that it seemed to do towards cooling the oil and pushed us into overheat terriotory for the cooling system.
Perhaps if we had a much larger radiator on the van things would have been different.
Rammie2000
Member #: 10190
belgium
Alright look into that. Can't weld the aluminium so wil be thread for me.
Intresting about that exchanger. So other than adding quit some weight its good for the looks. No wonder i never seen them.
This is what I use:
http://www.ebay.co.uk/itm/Garrett-GT25-GT2...t-/361104096202?
Can't find a picture of it fitted, but yoy can see it on this video:
https://www.youtube.com/watch?feature=playe...e&v=5Pipx9ECDAQ
Rammie2000
Member #: 10190
belgium
Looks neat. Where does that feed commes from then?Looks like from where the oil presure switch commes. Does that give enough feed?
Yes, feed from the oil pressure switch connection.
Rammie2000
Member #: 10190
belgium
Owkey. Awesome. Ill look for some like that. Hmp its about time to have some budget to get the engine parts... engine in pic is just mokupp engine for scrapping. (I thinck ill make a coffee table out of it afterwords. )
