| Home > Help Needed / General Tech Chat > clutch and needle | |||||||
53 Posts Member #: 9238 Advanced Member |
6th Nov, 2014 at 11:36:10pm
hi took my meter standard mini engine turbo gt turbo intercooler 17 and I really slipping the clutch embrague¿que you advise me to mount?
6th Nov, 2014 at 11:48:20pm
what clutch setup do you run?
6th Nov, 2014 at 11:53:48pm
I installed aem wideband |
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
7th Nov, 2014 at 01:34:14pm
is it a standard clutch setup? has you carb needle been profiled? Done now needs redoing lol |
7th Nov, 2014 at 10:30:13pm
hello, the clutch is standard.
8th Nov, 2014 at 08:06:04am
if your running good power bhp you will need to upgrade your clutch and you need to take the car to a rolling road tune so they can adjust your needle Done now needs redoing lol |
8th Nov, 2014 at 10:11:07am
and suggest I put the clutch? |
8th Nov, 2014 at 11:23:00am
On 8th Nov, 2014 gttalpine said:
and suggest I put the clutch? are you trying to ask which clutch to use? if you are it all depends on your engine spec Done now needs redoing lol |
8th Nov, 2014 at 09:22:22pm
if that mean.
Edited by gttalpine on 8th Nov, 2014. |
