Home > Help Needed / General Tech Chat > spacers?
m4dn35s
Member #: 243
Portsmouth
Hi all,
Jus got my head back from being reconditioned so can now put the engine together, When i first got the turbo head it came with some round spacer's that went between the head and the inlet manifold, they sort of sat in the ports of the head do these need to go back on? or do they get chucked? cheers hope i make sense.
Cheers matt *smiley*
WooHoo Passed it's MOT!!!! One of the cars in The Portsmouth Mini Turbo Massive!!
most people I belive dont use them, I don't
They are handy for lining up the manifold and head
They're not essential, but I use them even if Jim dosen't so Neeerrr.
Wil
I use them also.
Won't make a huge difference either way though
my head and inlet manifold has been opened out, so I can't use them, but they do help line everything up.
mikemph
Member #: 449
Oxford
I haven't bothered on my build either. Same reason my head has been opened out.
m4dn35s
Member #: 243
Portsmouth
Thanks guys. my head is stage 2 so il leave them off if there not that important.
matt *smiley*
i dont use them
but then my cars slow so dont listen to anything i say!
I use them.
think of the weight!!!
hario
Member #: 2885
The inlet manifold I have has had the lower section of the lugs (that the studs clamp down on) removed allowing the manifold to be lifted straight up and off once the studs have been slackened, negating the possibility of using those round things.
Not sure if this is standard? I guess not..
if you have them use them
if you dont! No worries dont make any diffrence.
