Home > Help Needed / General Tech Chat > Diff pinion teeth
wolfie29177
Member #: 476
The Black Countraaaaay
Ok I've been a retard and mixed up some 3.2 and 3.1 diff parts. Anyone know how many teeth on the pinion wheels and diff wheel so I can work out which 1 is which?
Masturbation is not a crime its a hobby
Tupers
Member #: 9441
South Devon
Both use a 19 tooth pinion but the 3.1 uses a 59 tooth crown gear and a 3.2 uses a 61.
Both pinions are DAM2808 per calvers very useful links:
http://www.calverst.com/articles/Gearbox-F...es_standard.htm
wolfie29177
Member #: 476
Thanks lads
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
if you didn't already know diff ratios are just dividing the crown wheel and pinion tooth counts
same for any gear ratio or combo
PhilR
Member #: 10034
Birmingham
You need to check the part numbers. Luckily, Wolfie's gears are interchangeable but...
On 23rd Nov, 2014 Keith Calver said:
- Although some gears have the same tooth count for different ratios, they are not interchangeable - hence the need for distinguishing part numbers. Therefore use in known pairs only.
- A+ gears have a different tooth profile to pre A+, so they are not interchangeable.
Edited by PhilR on 25th Nov, 2014.
wolfie29177
Member #: 476
they're both from A+ boxes Phil so shouldn't be a problem. Both are in good nick so I can't see an issue but thanks for everyones help
Nick king
Member #: 9646
Bristol England
Hay guys I've not worked on the final drive yet, but from what's been said I'm a bit confused. How can two different ratios have the same size pinion gear, surly if the crown wheel has more teeth then it's diameter must be bigger therefore the pinion needs to be smaller, as the shaft centres are fixed. If the pitch/tooth profile is altered to accommodate the fixed centre dimension then the pinions must all be different for all different ratios. Maybe the same amount of teeth but a different shape. Or have I missunderstood.
You have mis-understood.
The module doesn't have to be a round number in tooth geometry, it can be to several decimal places, to allow for the form to be "cheated" to allow different tooth count gears to work with the same tooth pinions (or vise versa when you have similarly sized pairs of gears).
It is a little more complex to achieve this with helical gears rather than spur gears, but a 59 to a 61 gear is only a 3% difference, so is pretty much in the realm of adjustment within the allowable tooth form which is what makes it work. Conversely however, there is no way that you could ever run the same larger gear, with different (much smaller) pinions in a helical form. Something like a 1.1ratio between a pair of gears, it is likely that the ratio coule be adjusted very easily by several teeth up or down to adjust a ratio for underdrive or overdrive -this is basically what the different drop gear ratio's achieve. Another example is the "overdrive" helical set used in the HLE metro's - they were something like a .91 overdrive... Very cool and something I wish I knew about 15 years ago when HLE metro's were all over the place.
viz139
Member #: 9182
I never understood how they changed the ratio of the drop gears in the HLE. If you change the diameter of the idle gear the primary and 1st motion must change by the same amount as they are a fixed distance apart unless the idle gear center was also moved. Am I missing something?
Please read the post above.... You are missing something...
The PCD of the gear is "theoretically" the mid-point of the tooth in laymans terms, and all the PCD's of a gear train are aligned (not overlapped or not contacting).
But in reality, the PCD can be outside or inside of this theoretical "mid-point, and the tooth form can be adjusted to allow for a slightly "thinner", "taller", "fatter", "shorter" tooth form to be used, and still function against another (un-changed) gear.
Basically, you can squeeze a few more, or a few less teeth (usualy no more than 8-10% however) into a single gear, and still achieve a satisfactory meshing with an unchanged pair.
Nick king
Member #: 9646
Bristol England
Well that is a brilliant explanation, thanks. So I was sort of close in my thinking.
So many ways of adjusting and fine tuning the drive ratios, is that because of race engines running very narrow power bands?
wolfie29177
Member #: 476
This is why formula 1 cars use helical rather than straight cut gears. They say changing ratios over quickly is a lot simpler with helical gears (this nugget of useless info came from a family member who worked for an F1 team)
viz139
Member #: 9182
Got it now ,thanks.
So which would put less pressure on the gearbox, increasing the drop gear ratio or increasing the final drive?
Overdrive drops of a .90 ratio would reduce the input torque by 10%, but the biggest gain is by widening the ratios (making them still a closer-ratio than the A+, but allowing us to make use of the much wider torque-band of our turbo engines). The other benefit is that the taller ratio (numerically lower) of FD that you'd probably then go with, also has lower bearing loads than a shorter (numerically higher) FD ratio...
The only extra "losses" is losing a small amount of efficiency as it takes more "effort" to turn the gears in the transmission becuase you've overdriven them and are driving them faster. That said, I suspect the benefits would be advantageous - if you could just get over the little detail of actually doing it....
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
so over drive drop gears should really do done if you dont want straight gears and want to run decant power
