| Home > Help Needed / General Tech Chat > Oil temp sensor | |||||||
976 Posts Member #: 3228 Post Whore North of the Netherlands |
24th Nov, 2014 at 04:08:16pm
I know most of you guys plug a sensor in the gearbox but I have one of these which simply bolts on:
Dazed and Confused.... |
24th Nov, 2014 at 06:58:34pm
Looks good, the temp wont change greatly as it goes round the system. |
108 Posts Member #: 9182 Advanced Member |
27th Nov, 2014 at 09:52:19am
Can't remember the exact science but as the pressure in a liquid changes so does the temperature ( how a fridge works).Your at max pressure point as opposed to the sump at no pressure.MPi sensor is in the block.Which is the most relivent ,block or sump temp? |
28th Nov, 2014 at 12:27:59am
though it was the friction of pumping that made heat not the actual pressure?
28th Nov, 2014 at 10:07:24am
At the end of the day your just splitting hairs, the oil is in a closed loop so no matter where you sample it your getting a representative value of how hot it is. |
28th Nov, 2014 at 10:22:16am
the temp change can be calculated
28th Nov, 2014 at 10:45:36am
fridges work by phase change. if your changing your oil to a gaseous state, theres something wrong :) I think that location would be fine for oil temp, if anything it probably better represents the oil temp seen by working components than the temperature in the sump. turbo 16v k-series 11.9@118.9 :)
29th Nov, 2014 at 07:24:07pm
Thanks for your input guys, much appreciated.
