| Home > Help Needed / General Tech Chat > Grind case for Quaife LSD | |||||||
64 Posts Member #: 6668 Advanced Member |
30th Nov, 2014 at 11:05:24pm
Hello all, 5626 case, Quaife LSD. Is it necessary to grind out the diff area to fit this? Racecar spelled backwards is Racecar |
1st Dec, 2014 at 01:22:00am
Yes. Trans case and the diff cover. On 17th Nov, 2014 Tom Fenton said:
1st Dec, 2014 at 07:34:09am
Why would you grind a transfer case to fit a diff? On 11th Feb, 2015 robert said:
![]() 539 Posts Member #: 6807 Post Whore York |
1st Dec, 2014 at 07:37:45am
Transmission case |
1st Dec, 2014 at 07:05:50pm
Dry build and see - I only had to tickle a bit out of the diff cover. |
1st Dec, 2014 at 07:08:31pm
I never had to touch mine On 28th Aug, 2011 Kean said:
1st Dec, 2014 at 07:08:33pm
1st Dec, 2014 at 09:01:12pm
Never did mine either |
1st Dec, 2014 at 09:02:36pm
Nor me On 7th Oct, 2010 5haneJ said:
1st Dec, 2014 at 09:20:48pm
IIRC LSD's bias the other way to std diffs, that might be the issue. On 28th Aug, 2011 Kean said:
1st Dec, 2014 at 10:38:55pm
It'll maybe also depend on what CWP and hence the OD of the crown wheel. The differences nay be slight, but could be just enough to cause some interference. Mine was 3.7 |
1st Dec, 2014 at 11:24:44pm
1st Dec, 2014 at 11:29:18pm
2nd Dec, 2014 at 03:27:06am
Well i guess I was plain unlucky... Both my gearbox (transMISSION) case and diff housing needed attention. It was a surprise as I thought it was a "drop in" fitment... On 17th Nov, 2014 Tom Fenton said:
2nd Dec, 2014 at 10:34:39am
3.7 in mine .
Edited by cossierick on 2nd Dec, 2014. |
