| Home > General Chat > Side mount manifolds K1100 and 5 port | ||||||||||||||
3rd Dec, 2014 at 07:10:11pm
AllRiiiighty.... I realize polls usually go arwry but...
3rd Dec, 2014 at 07:19:47pm
Well the gt17 and gt20 are both t2 flange so that end is easy not so sure with the gt28 but a t3 flange is only slightly larger
Edited by Brett on 3rd Dec, 2014. Yes i moved to the darkside |
3rd Dec, 2014 at 07:33:10pm
Yes yes yes!! In the 13's at last!.. Just |
3rd Dec, 2014 at 07:51:37pm
Ah thanks Brett thats interesting, didnt realixe the 17 and 20 were the same bolt holes.
3rd Dec, 2014 at 08:09:32pm
I think most would be happy using a square flange with the GT17. There's enough meat in the turbine housing to blend it in if anyone fancies it. In the 13's at last!.. Just |
3rd Dec, 2014 at 08:25:40pm
That is a good point the gt20 is indeed a square hole T2 flange
3rd Dec, 2014 at 09:33:27pm
You might want to consider an option for AFR sampling chambers that the 5-port EFI guys are using. Or at least see that fitting them is possible with whatever configuration you come up with. |
3rd Dec, 2014 at 10:45:46pm
On 3rd Dec, 2014 jbelanger said:
You might want to consider an option for AFR sampling chambers that the 5-port EFI guys are using. Or at least see that fitting them is possible with whatever configuration you come up with. my thoughts the same jean
432 Posts Member #: 2726 Senior Member wakefield |
3rd Dec, 2014 at 11:30:37pm
Definitely be interested in a gt2056 sidemount.
3rd Dec, 2014 at 11:31:16pm
For the 5 port tht is..... |
