Home > General Chat > spluttering off boost
tomostrash
Member #: 10334
Staffordshire
Hi folks my mini turbo splutters off boost but ok over 2000 rpm and if I pull the choke out when pulling off, the co is set to 3.5 but I'm suspecting its running lean. Any idea?
so the CO is set to 3.5 at idle?
what says the needle is correct ?
if pulling the choke out helps is too lean, i would suggest getting it rolling road tuned
if its only just started ( and was running correctly through summer )
it may need 1/4 turn richer on the mixture screw
as bret says ..................... also you need one of these pronto http://www.ebay.co.uk/itm/AEM-Wideband-AFR...#ht_1736wt_1141
in short!!! the fuel ratio needs to be 12.5 under wide open throttle under boost
