| Home > Help Needed / General Tech Chat > Fuel pump flow comparisons - and lots of other nice parts... | |||||||
5th Dec, 2014 at 11:19:28am
Fuel pump testing:
5th Dec, 2014 at 01:35:12pm
Weber Alpha do q nice reg. I wont recomend anything else On 26th Oct, 2004 TurboDave16v said:
5th Dec, 2014 at 01:40:06pm
The walbro 255 is a noisey fucker! I can simewhat comfirm that... You can hear it whine frome the driver seat On 26th Oct, 2004 TurboDave16v said:
5th Dec, 2014 at 03:22:42pm
yeah, I've run the walbro since '06 - quiet it is NOT!
5th Dec, 2014 at 06:23:43pm
the walbro 255 is a shit load quieter than a nismo gtr pump Yes i moved to the darkside |
5th Dec, 2014 at 06:51:54pm
The Walbro 255 is even noisy used "in-tank" :(
5th Dec, 2014 at 07:09:53pm
what do you guys call quiet then? the walbro 255 is genuinely the quietest pump i have used so far
5th Dec, 2014 at 09:17:08pm
skyline is a plastic tank under a boot floor, not a metal tank a few feet from the drivers seat :) Weldon do a nice noisy fuel pump if thats your thing. never found 044's to be that noisy?! especially if rubber mounted somewhere out the way. turbo 16v k-series 11.9@118.9 :)
6th Dec, 2014 at 08:21:48am
On 5th Dec, 2014 TurboDave16V said:
The weber reg being the one with the "cone" shaped top? http://www.burtonpower.com/weber-alpha-fue...CFQHJtAodTV8AUQ On 26th Oct, 2004 TurboDave16v said:
6th Dec, 2014 at 10:58:56am
That's basically the same generic Bosch flanged regulator in a different housing??? On 17th Nov, 2014 Tom Fenton said:
89 Posts Member #: 2380 Advanced Member Hamburg, Germany |
6th Dec, 2014 at 12:55:55pm
yes
On 6th Dec, 2014 TurboDave16V said:
That's basically the same generic Bosch flanged regulator in a different housing??? |
6th Dec, 2014 at 02:43:36pm
I agree then lol...
![]() 1434 Posts Member #: 8466 Post Whore Mansfield |
6th Dec, 2014 at 05:59:00pm
Can I just ask
Class C 3rd Place Avon 2011 14.18 @101mph |
6th Dec, 2014 at 06:25:14pm
Short of the pumps using the fuel as a Heat-soak (don't know if they do, but I imagine it's feasible) I suppose you can make them work.
3596 Posts Member #: 655 Post Whore Northern Ireland |
6th Dec, 2014 at 06:35:18pm
On 5th Dec, 2014 Brett said:
what do you guys call quiet then? the walbro 255 is genuinely the quietest pump i have used so far you can only just hear it in the skyline ( engine not running) Would have to agree. Fitted dozens to Subarus and noise is never even a concern. 044 is louder, but even those when mounted correctly arent bad. With engine running no way would you hear either unless badly mounted and/or car has no soundproofing whatsoever. 9.85 @ 145mph
6th Dec, 2014 at 06:36:39pm
On 6th Dec, 2014 alaskanow0 said:
Can I just ask Can you install a internal pump externally? Would a bosch 040 be ok for Nat Aspirated 150bhp A series Mini? Also any disadvantages running a larger than needed pump, except current usage and noise? You cannot use an in-tank pump externally. And an 040 would support 500hp or so at fuel injection pressures....I'd guess maybe 6-700hp at carb pressures. So might be a little overkill for only 150hp. Walbro do a 190lph in tank if that's what you need, or they offer in-line versions too. 9.85 @ 145mph
6th Dec, 2014 at 06:50:14pm
Stevie, mine is very loud for a pump... But it is literally 5ft from my ear... On 17th Nov, 2014 Tom Fenton said:
6th Dec, 2014 at 08:30:52pm
Thanks for the info.
6th Dec, 2014 at 09:07:24pm
Thanks for the info. I've bought a external bosch 044, thinking it was the same as the standard Turbo pump. I wanted the AN fittings, but my concerns how it's actually a lot bigger, 409g heavier and sounds to be overkill. Maybe a should stick with the Standard Turbo pump? Bosch do a smaller pump that has threaded fittings at both ends, not sure which part number it is though. Some googling would suggest the 979, M14 inlet and M12 outlet and much reduced flow compared to an 044 http://www.boschfuelpumps.com/ ( silly prices ) 044 is probably 7-800hp at carb pressures lol And 6-700 at efi pressures, also draws reasonable current at efi pressures compared to some pumps. At around 55-60psi mine draw about 11A each, this will rise as pressure rises Walbro do some inline pumps too with threaded fittings. http://walbrofuelpumps.com/walbro-gsl-seri...line-fuel-pumps 9.85 @ 145mph
6th Dec, 2014 at 09:10:59pm
And std metro turbo pump is same as a few cars of that area.
6th Dec, 2014 at 09:34:41pm
Yep the 979 looks slightly better. But still based around the 044, by the looks of it.
7th Dec, 2014 at 12:24:36am
Almost all the Bosch pumps are about same externally, same size etc. Or very close.
Site Admin ![]() 9407 Posts Member #: 58 455bhp per ton 12 sec 1/4 mile road legal mini Sunny Bridgend, South Wales |
8th Dec, 2014 at 09:50:00am
you can hear your fuel pumps??? I assume this is with the engine off??? On 15th May, 2009 TurboDave said:
8th Dec, 2014 at 02:58:36pm
In a fairly stripped car, or if the pump is not mounted on suitable rubbers, they can be pretty loud
8th Dec, 2014 at 04:18:47pm
On 8th Dec, 2014 stevieturbo said:
In a fairly stripped car, or if the pump is not mounted on suitable rubbers, they can be pretty loud But mounted on soft rubbers and they noise is nothing to worry about. I've two running all the time on my car, and the noise is very quiet. On the other hand, a stripped out race Subaru I work at has one semi crudely mounted to an alloy boot floor infil ( on the underside ) with a jubilee clip and a thin bit of rubber around it, and the noise from it is pretty horrendous Sounds like how mine is mounted. I have an alloy mount welded to my fuel tank with the pump solid mounted to it. Maybe my engine is too loud On 15th May, 2009 TurboDave said:
