| Home > Help Needed / General Tech Chat > Pot Joint In Pieces | |||||||
168 Posts Member #: 10666 Advanced Member California, USA |
6th Dec, 2014 at 06:59:44am
Right so I got my subframe out and started taking apart the suspension and driveshaft components for cleaning and overhaul.
6th Dec, 2014 at 07:50:54am
Just grease it up, stick the ballbearings in wherever and put it back in the pot joint. On 26th Jan, 2012 Tom Fenton said:
6th Dec, 2014 at 07:55:26am
That easy? And here I was all worried that I'd have to buy a new one! :)
6th Dec, 2014 at 09:03:25am
the only thing to worry about is the center ball 'cage', it fits over the driveshaft section and then the balls fit between the gaps,
Yes i moved to the darkside |
6th Dec, 2014 at 01:00:03pm
I've had ballbearings fall out loads of times, don't think ive ever pulled the cages apart, it's always a pain when you finally put the engine in and look underneath and theres a stray ball on the floor! On 26th Jan, 2012 Tom Fenton said:
6th Dec, 2014 at 01:05:26pm
On 6th Dec, 2014 Carlzilla said:
I've had ballbearings fall out loads of times, don't think ive ever pulled the cages apart, it's always a pain when you finally put the engine in and look underneath and theres a stray ball on the floor! Im quite sure if they fall out there warn, its no big deal obviously I always split the ball joints when pulling the engine, Yes i moved to the darkside |
6th Dec, 2014 at 07:48:43pm
These are one of my big bears on Minis. I don't like pulling them apart all the time. It's possible to knock the inner race sleeve off the end of the driveshaft hence leaving the joint intact not disturbing it.
it was a long night replacing those intime to get down to MITP
