| Home > Help Needed / General Tech Chat > Homemade manifold idea | |||||||
57 Posts Member #: 10219 Advanced Member |
8th Dec, 2014 at 10:03:44pm
Just looking for some help on my manifold idea working , picture shows a metro manifold with 2x flanges from lcb manifold one will be welded to metro manifold then other to t2 plate . With lcb manifold pieces welded Inbetween with a flexi for expansion. Will the size of pipe cause a flow issue from turbo to manifold . http://s46.photobucket.com/user/Sam413522/...a08bd8.jpg.html Edited by sam138 on 8th Dec, 2014. |
9th Dec, 2014 at 12:23:22am
I dont think the pipe size will be your problem. Are you implying you are going to weld the steel pipe to the cast iron manifold? that wont work. |
9th Dec, 2014 at 01:13:38am
I wouldn't put a flexi pipe before the turbo. If it's springy steel with braiding over the top, I can imagine it overheating, loosing it's springy-ness and failing. Design a support that holds the weight of the turbo, but not so rigid that it stops the pipes expanding how they want to. Edited by PhilR on 9th Dec, 2014. |
9th Dec, 2014 at 01:06:27pm
You can get various flexi's or slip joints if you really needed one.
9th Dec, 2014 at 03:37:24pm
Don't forget the pressure pre-turbo is more than a flexi tube would be expected to see. If it doesn't give way, I have a vision of it stretching like a concertina when the turbo spools!
9th Dec, 2014 at 04:44:06pm
Looks ok, but you might want to use better material than the LCB pipe. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
9th Dec, 2014 at 05:42:00pm
Looks okay, as wil said I'd get it made up in stainless at an exhaust place, and make sure you create a support for the turbo, heat wrapping or coating the manifold extension/adapter would probably help too. On 26th Jan, 2012 Tom Fenton said:
