| Home > Help Needed / General Tech Chat > brakeline | |||||||
![]() 1751 Posts Member #: 10190 Post Whore belgium |
11th Dec, 2014 at 01:32:45pm
where do you guys get your brake line's? i know i'm overseas but 2 years ago i bought 10 m for 20 pounds.
89 Posts Member #: 2380 Advanced Member Hamburg, Germany |
11th Dec, 2014 at 03:28:57pm
i buy CuNiFer (i don't like them rust again) brake line here: http://www.korrosionsschutz-depot.de/shop_...sleitungen.html
11th Dec, 2014 at 08:58:58pm
I just use copper line, its about a tenner for 5m,kunifer is supposed to be better and looks nicer, little harder to work tho but still way easier than steel. not much dearer too. turbo 16v k-series 11.9@118.9 :)
11th Dec, 2014 at 09:25:33pm
i used to use copper to. have been looking at cunifer because i like the look. but not sure how my set would react to it. a tenner? 10 pounds? where do you get it? you can do anything if you set your mind to it...
11th Dec, 2014 at 10:30:12pm
just factors around here, about that on ebay too turbo 16v k-series 11.9@118.9 :)
12th Dec, 2014 at 09:28:49am
I've got steel and copper.
12th Dec, 2014 at 09:59:26am
If you use plain copper, bear in mind it has very low resistance to fatigue compared to steel so should be supported better, especially in areas the pipes might vibrate.
12th Dec, 2014 at 04:30:38pm
Its for the regular lines on the mk 1 first. Once budget commes back again i work further on the turbo. But on that one i would like to see the lines running inside of the car. How much would i need per car ( i stil have about 3 meters but can't remember how big that rol was when it was new. About 9 meters on each car? you can do anything if you set your mind to it...
12th Dec, 2014 at 06:20:13pm
I used about 10M on my car with dual lines. You would get away with less but better to be safe. I think I messed up about 2M worth.
12th Dec, 2014 at 07:17:11pm
Okey. I'll look around on the bay then. Only one day of welding left..... i hope. you can do anything if you set your mind to it...
12th Dec, 2014 at 07:19:29pm
Ps. I noticed some serious dents ( not deep but big in surface in a door and one side of the car...) aprox 0.5 cm deep but 30 on 30 big. Thought about welding some wire to the midle of it and heat up while pulling what you guys recon? you can do anything if you set your mind to it...
