Home > Show Us Yours! > mk 1 traveler woody all finished. 😎😎
Rammie2000
Member #: 10190
belgium
https://www.facebook.com/media/set/?set=a.1...=1&l=72bfe7aa4c
this is my mk1 traveler bought for 250 euro ( 220 pounds) 2 years ago. it spend approximately 15 years at minimum to 20 years top on its side in a damp "garage" ( more like a barn) i'm second owner from new.
the right hand side needed stretching 17mm to get the door in.
(hope the link works)
Edited by Rammie2000 on 20th Feb, 2019.
Nice work and have to say a bargain. I've got an early traveller sitting ready for resto too
Rammie2000
Member #: 10190
belgium
thanks. just spend 3 hours today to get the last a-panel on its place... but hey slow but sure.
viz139
Member #: 9182
Did you change the floor or was it done already?
Rammie2000
Member #: 10190
belgium
it has had a "new" floor somwhere in its life and a remote gearbox ( with 850cc engine) instead of the magic wand. did need some straightening out though. i had tought about changing it back to correct spec but since the 1100 is remote to...
viz139
Member #: 9182
I'm looking at changing an Elf floor (whats left of it)to a later floor with larger tunnel for turbo exhaust and remote, just wondering if there is anything to watch out for.
Rammie2000
Member #: 10190
belgium
a like that. as i looked into changing it back i was thinking on only cutting out the tunnel then weld a "lip" to the new tunnel so i can just weld it back to the floor that is in there.
Rammie2000
Member #: 10190
belgium
hi all. as i am making up the brake and fuel pipes for the traveler i stumbled on a problem. it seems that 8 mm copper tube ( od, about 6mm id) is more available than the standard 6 mm tube. i would not mind placing a thicker 8 mm tube only i worry about 2 things.
1 will it fit the fuel tank ( with the screw on coupling or how would i make it fit.
2 will the fuel line not be to thick for the pump ( i have been thinking about things like not beeing able to cope with the bigger diameter and so not able to pull the fuel or something probably nothing to worry about)
as an extra i was wondering what the advantage would be of a small su or facet pump instead of the mecanical pump
it will be a standard 1100 cc engine with a single hif 38 carb .
greetings
the early cars ran an electric pump mounted to the rear frame. given originality is out the window, I'd fit a pump as you suggest
Rammie2000
Member #: 10190
belgium
well it needs as original as posible but since it will be the car my wife is going to drive around from belgium to uk en ierland and so on i want it to be as reliable as possible. and i can easilie hide a pump that size near the subframe or so. but would like to know what the advantage would be. and if i could get away with 8 mm line's. greets.
Yo-Han
Member #: 3228
North of the Netherlands
You can get all kind of unions for those pumps to adjust to your requirements.
Not sure what bennefit it would give to be honest, I personally have never seen a mechanical pump fail..
Dazed and Confused....
Rammie2000
Member #: 10190
belgium
I had a mechanical pump fail long time ago. Still don't know how it happend but has pumped fuel into the engine itself ( mixed with the oil) ruined all my rubber seals in an instant. Never had it since though.
Rammie2000
Member #: 10190
belgium
So instead of cleaning the tank up and mounting it i ended up welding it. And the rust story goes on.
adcyork
Member #: 6807
York
I'd advise that you run some petseal round the inside of that filler neck as it'll almost certainly have a few pin holes in the welds which will leak fuel vapour/liquid under the paint and cause it to bubble
Rammie2000
Member #: 10190
belgium
I filled it with water and put some pressure on it. Didn't leak... what is pet seal?
Rammie2000
Member #: 10190
belgium
Hello!
rammie2000 shared an album with you.
View Album, http://s1213.photobucket.com/user/rammie20...ini%20esmeralda
Getting close to stand on wheels now. Rear sub already fully build.... just need to get it of the table now.
Edited by Rammie2000 on 19th Feb, 2015.
Rammie2000
Member #: 10190
belgium
rivets broke off... need to get these out *frown*
dichwasser commes in handy
head needs allot of work...
happy with what it become so far
o and its on her feet to
foto's on that later
I do keep wondering about getting a dishwasher for the workshop
Rammie2000
Member #: 10190
belgium
its a great thing... no more endless scrubbing and thinner...
Rammie2000
Member #: 10190
belgium
rear sub build up
Rammie2000
Member #: 10190
belgium
rolling shell nice
Rammie2000
Member #: 10190
belgium
took me long enough since the hole front end wasnt straight any more ( bend up doors didnt fit etc) but happy with it so far...
Rammie2000
Member #: 10190
belgium
http://www.classicproof.com/tinwork/1967-mini-traveller/
not that much is changing since the divorce is costing me money enough ( and i was lucky to keep it) but they did make an article about it... it might be me but im proud off that!
looks like it is coming together now. what colour are you going for?
