| Home > Help Needed / General Tech Chat > K1200 distributer drive | |||||||
64 Posts Member #: 6668 Advanced Member |
16th Dec, 2014 at 03:08:57pm
Hello, Has anyone run a k1200 conversion with a distributer? Being a technology dimwit I am not looking forward to mapping and all that. Looking at the cam/oil pump drive I am wondering if the partial contact the drive belt has on the pulley would allow for accurately driving the distributer? Racecar spelled backwards is Racecar |
16th Dec, 2014 at 04:09:36pm
16th Dec, 2014 at 04:19:37pm
Love Captain Kirk ! Been cracking up watching the Shatner project. Racecar spelled backwards is Racecar |
16th Dec, 2014 at 04:40:27pm
erm,
17th Dec, 2014 at 10:10:26am
Just run megajolt and pay someone to map it for you. Less of a headache for yourself |
17th Dec, 2014 at 11:09:55am
Yeh, you'd be better off running a base map than clockwork. It's not hard to fit a coil pack and ecu either you don't have to be an electronics genious |
65 Posts Member #: 9646 Advanced Member Bristol England |
17th Dec, 2014 at 08:30:57pm
Yep it does work, I ran mine on a dizzy n bike carbs to start with until I got my head around a Megasquirt ecu set up. It worked fine. I'll find a pic. Check out you tube, search nick 07870. It's alive. |
19th Dec, 2014 at 11:42:44pm
Maybe overstating luddite tendency but the first engine will go into the endurance racer. So for simplicity a 123 distributer and carb is the order for the day. First choice would be a SU HIF 44 but it may see a DCOE. The second engine will be on a standalone ECM Racecar spelled backwards is Racecar |
