Home > Help Needed / General Tech Chat > random cutting out/missing
First major problem we've now encountered, it randomly cuts out at idle as if someone has turned the ignition off and it missed but came back to life a couple times whilst driving over 40ish miles. It's never done this before, but I have just filled up the tank, so maybe it's dodgy fuel? It's on mj v3 and a 998 turbo, never had a problem with it before now, i really hope it's dodgy fuel, anyone experienced this before?
Carl S
Member #: 1761
Stalker
Check the crank sensor position and clearance to make sure it's correct?
Used half a tank and refilled with vpower, problem disappeared, I'm glad it was just a batch of shit fuel as i suspected!
if it happens again look for a dodgy wire ..... to ..... the ignition system
Carl S
Member #: 1761
Stalker
Fair enough, glad it was easy enough to cure
Well, it kept happening, and in the end it turned out to be a loose/corroded coil power connection behind the grille as the weather had got to it. Steve was bang on the money, it must have been purely coincidental that it happened shortly after filling up!
