| Home > Help Needed / General Tech Chat > turbo diagnosis | |||||||
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
18th Aug, 2005 at 10:34:49am
ok folks i took the elbow off the manifold on the turbo yesterday in order to port it out and remove any potential areas that may cause a bottle neck. when i took off the elbow i checked the fan in the main housing (not the garrett fan) i noticed there is a small amount of lateral play on the fan.............is this goosed ?
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
18th Aug, 2005 at 10:40:14am
When you say lateral which way do you mean?
18th Aug, 2005 at 06:51:07pm
radial by about 1 - 1.5mm turbo unit is dry ie no oil.
18th Aug, 2005 at 07:33:11pm
Radial is not the end of the world, it is axial that equals a dead turbo. At least I think that is the right way round?
18th Aug, 2005 at 07:55:28pm
good old guesstimate
18th Aug, 2005 at 08:16:03pm
should be ok so long as you cant pull it back and forth AS WELL.
AlexF |
i will just have to suck it and see if it blows smoke like a rasta then i know what the answer is just a pain if i could have rectified it prior to engine going in
