| Home > FAQ / Knowledge > Gearbox help request | ||||||
![]() 209 Posts Member #: 6451 Senior Member South East Northumberland |
29th Dec, 2014 at 01:15:23pm
Hope you've all been enjoying the festive break. My project has been to rebuild the gearbox I'm going to be using on the Marcos (eventually), and I've come across a problem I haven't been able to solve with the Search button - I'm hoping someone can advise.
29th Dec, 2014 at 02:07:55pm
If it will engage one gear on the hub, it should be together properly. Only thought is about the baulk ring being in the correct place. Otherwise be a bit tougher on the change, they can be quite stiff until the engine oil was worked around the gears. On 11th Feb, 2015 robert said:
29th Dec, 2014 at 02:54:57pm
The left (geared) hub is for 1st and 2nd, the right hub (the one you're having trouble with??) engages 3rd and 4th.
On 29th Dec, 2014 Cooper1999 said:
Edited by PhilR on 29th Dec, 2014. |
29th Dec, 2014 at 03:10:31pm
Cheers Gents - I think you were both correct.
Edited by Cooper1999 on 29th Dec, 2014. |
29th Dec, 2014 at 03:23:18pm
I was just about to say... Careful not to move it too far. It's a pain once your balls fall out. In the 13's at last!.. Just |
29th Dec, 2014 at 03:43:13pm
Oops, no, you don't won't your balls bouncing around.
29th Dec, 2014 at 04:02:48pm
30th Dec, 2014 at 05:41:20pm
Of course - the ball and spring which engages in the three rounded positions in the 'hockey stick' shaped selector!
30th Dec, 2014 at 06:04:04pm
If you gave it a good whack, I think it could still overshoot even with the detent ball in though.
Edited by PhilR on 30th Dec, 2014. |
30th Dec, 2014 at 10:53:28pm
i found it helped to turn the box over as i pushed/pulled on the selector as phil said the bulk rings can stick a bit |
31st Dec, 2014 at 02:41:58pm
Okay - so this is where I'm at.
Edited by Cooper1999 on 31st Dec, 2014. |
31st Dec, 2014 at 03:05:23pm
Put the spring washer in the first motion bearing slot and put the third motion retainer on. That will keep everything nicely lined up. On 11th Feb, 2015 robert said:
31st Dec, 2014 at 03:07:01pm
You need to put the plate on that retains the main shaft bearing at the pinion end. (The C shaped thing with with 3 or 4 holes in.) That will push the bearing all the way in the housing and the gears will line up then. Torque up the mainshaft nuts to 150ft/lb by locking it in two gears at once. Theres not really any point in checking it works until you have at least tightened both ends. |
31st Dec, 2014 at 03:09:33pm
You should also check the pre-load on that bearing. If you have a decent manual it should explain how. |
1st Jan, 2015 at 09:58:33am
dont forget the reverse shaft locking plate the little triangle shaped bit you can use that to help hold the shims in place to if you like buy pushing on the pin
1st Jan, 2015 at 11:47:56am
Get a metro Haynes manual rather than watching that twonk from MiniMania. In the 13's at last!.. Just |
2nd Jan, 2015 at 01:44:28pm
Right - got myself an older Haynes manual (why did the remove so much gearbox info from the later books?) and have got the box together. I still don't have the lower transfer gear to be able to do that end nut up to 150ft/lbs, but have carried on rebuilding the diff.
2nd Jan, 2015 at 02:16:35pm
With the diff fitted and the cover on, you can't dissengage the gear selector levers to allow you to lock the box. On 11th Feb, 2015 robert said:
2nd Jan, 2015 at 02:19:29pm
On 31st Dec, 2014 slater said:
You need to put the plate on that retains the main shaft bearing at the pinion end. (The C shaped thing with with 3 or 4 holes in.) That will push the bearing all the way in the housing and the gears will line up then. Torque up the mainshaft nuts to 150ft/lb by locking it in two gears at once. Theres not really any point in checking it works until you have at least tightened both ends. This^^^ the main bearing will put those gears out in your pic if its not tapped all the way in, with that nut on as it is you can tap the end of the shaft ( with somthing soft) and it should go in more, look through the dif housing and iirc you can see when the ring on the Main bearing bottoms out on the gearbox casing... then you add the maimearing retainer and shim it. as already mentioned the metro manual is a good reference for this. at the drop gear end, just pop the big clip in and as ling as its in its groove thats fine, then add the drop gear and tigten the nut and everything will be where it should be. IMPORTANT! put the box in 1st and 4th when tightening the nuts to their 150ft/lb, this is the strongwst combination and people have snapped off teeth by using other combinations. On 28th Aug, 2011 Kean said:
4th Jan, 2015 at 04:15:50pm
On 2nd Jan, 2015 apbellamy said:
With the diff fitted and the cover on, you can't dissengage the gear selector levers to allow you to lock the box. Thought so. I'll store the box ready to be put on the engine, and move on to the next thing. Thanks for all the help and advice
Graham |
