| Home > Technical Chat > Undercooling Overheating | |||||||
68 Posts Member #: 9818 Advanced Member Leeds |
3rd Jan, 2015 at 12:02:11am
My problem has been over cooling when moving and overheating when stopped.
Edited by ERA1028 on 3rd Jan, 2015. |
3rd Jan, 2015 at 12:23:17am
a quick answer......... do you have a 74 deg stat fitted ? and what size water pump pully do you have on a large one or small ? my guess is it a larger type, anyway tis is just a start for more questions and and answers
3rd Jan, 2015 at 12:43:27am
It is a large pump pulley and an 88 degree themostat |
3rd Jan, 2015 at 09:41:18am
What condition is the pump in? could it be not pumping enough at idle, but with all your cooling mods, more than enough at speed?
336 Posts Member #: 9941 Senior Member Derby |
3rd Jan, 2015 at 10:02:37am
A small pump pulley would be a good help |
3rd Jan, 2015 at 10:32:24am
the "large" pulley slows the pump and fan speed vs the stock pulley large ones are mostly on high rpm/speed cars (stop start traffic ull want the small one)
3rd Jan, 2015 at 11:19:27am
The water pump is a new cast impeller type.
3rd Jan, 2015 at 02:07:52pm
stupid q era , i'm sure you have thought of, but is the electrical fan blowing the right way ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
3rd Jan, 2015 at 02:23:17pm
60 degrees is way too cool for the oil. Should be around 90-100 degrees. On 11th Feb, 2015 robert said:
3rd Jan, 2015 at 02:54:24pm
Robert had a good point about the fan. I'd also check the pump. Some of the new ones have too much clearance between the impeller and housing.
3rd Jan, 2015 at 04:27:11pm
The mechanical fan and the electric fan I fitted are working the right way round. How much is too much clearance at the impeller. I had it R/R at TMS in Knaresborough and it was fine. The guy there did a god job. As I mentioned when I increase the revs the temperature stops rising and can start to drop. I suppose this points to the larger pulley I have on. Putting the smaller one on will increase the pump speed. Anyone any idea the increase in rpm between the two 3.875 and 4.75. Is the Minispares high capacity pump GWP134EVO worth considering? But wont this increase the cooling while moving? The problem I want to stop also. My head is starting to hurt! |
3rd Jan, 2015 at 07:24:23pm
yes the smaller pully and HC pump is the way to start, take it from there and you head wont hurt ......lol
3rd Jan, 2015 at 07:50:08pm
if you didn't know those metal fans are fairly noisy
3rd Jan, 2015 at 07:55:38pm
On 3rd Jan, 2015 ERA1028 said:
before the water temp gets too a worrying level. Is there an electric fan that fits between the wing and the radiator that doesn't need the inner wing to be cut? ![]() What are you classing as worrying ? And I just fitted a thin Spal fine in my mini 20 years ago. This was in the inner wing area below the ERA airbox. Wouldnt say there as a ton of room, but there certainly wasnt a problem fitting it. Spal make some very thing and powerful fans, and make sure you get a puller. Then ideally if you can shroud between radiator and the inner wing to ensure as much air as possible always gets expelled externally, all the better Not a lot of room for a metal shroud there, maybe rubber, plastic, leather or something. As for the metal 4 blade fans, I had one, they sound terrible and sap a huge amount of power. And as others say, get a good quality pump and the smallest pulley you can. More water flow is always a good thing. 9.85 @ 145mph
3rd Jan, 2015 at 08:22:14pm
In my attempts to stop the overheating I fitted a fan under the wing as in the picture in my first post. It slowed the increase down a lot it worked very well but the temperature still rose. A lot slower but it still rose. I thought if I fitted one closer to the rad in the space between the rad and the inner wing it would pull more air through the rad. I made a shroud to go around the rad to close the gap.
3rd Jan, 2015 at 08:25:16pm
3rd Jan, 2015 at 10:40:57pm
All looks good, really that should have a good ability to keep things cool.
3rd Jan, 2015 at 11:18:42pm
I'll chip in and say that there is something simple wrong here but its difficult to pinpoint what it might be as i dont have half the information i would want to make reasonable suggestion.
Edited by Sprocket on 3rd Jan, 2015. On 26th Oct, 2004 TurboDave16v said:
4th Jan, 2015 at 01:07:39am
It is piped from the bottom of the main radiator to the aux radiator to a sandwich plate on the head below the thermostat and the top hose.
4th Jan, 2015 at 01:55:55am
As Sprocket says, it's strange you should even need an additional rad.
4th Jan, 2015 at 08:18:43am
It's difficult to tell from that photo (really need a close-up of it) but could the mechanical fan be on backwards ?
4th Jan, 2015 at 10:19:21am
Try blocking the extra rad as an experiment, perhaps (depending how its plumbed) its introducing cool enough water to shut the stat at even tho the engine is getting toasty. If it flows to return in the wrong place. turbo 16v k-series 11.9@118.9 :)
![]() 76 Posts Member #: 9169 Advanced Member Cape Town, South Africa |
4th Jan, 2015 at 11:14:47am
I think due to the way the auxiliary radiator is plumbed in there is too much coolent flow through the auxiliary radiator thus causing the temp to drop when driving and to heat when stopped(no air flow through the aux rad). Block the auxiliary and check if the temp behaves in the same way. |
4th Jan, 2015 at 12:37:26pm
The way the aux rad is plumbed in is as the original cars came from ERA so could be classed as standard. Because I have fitted a very efficient main rad that wasn't available in 1989 when the original was built I suspect that I have overdone it hence the to cool running. This is two problems I have to solve to bring the running temp up while keeping the standing temp normal. Some good suggestions so far some that confirm my own thoughts about the problem. ERA also used the turbo head with better cooling. The water galleries were bigger as you know. When I rebuilt the engine I used an MED turbo head. They didn't want the original turbo head because they said that it was difficult to machine as they could cut through to the water gallery so I supplied them with a standard 1275 head to work. I cant see that it would make a difference but it is a change from original.
Edited by ERA1028 on 4th Jan, 2015. |
4th Jan, 2015 at 12:53:58pm
Remove or at least clamp up a hose to the additional rad. It shouldnt be needed and is no doubt part of the overall problem.
