Home > Help Needed / General Tech Chat > CWP ratio with straight cut ST gearbox? (minispares clubman nearly same ratios).
jonny f
Member #: 9894
Dorking
After some recommendations, I've got either a 3.1 or a 3.44 CWP to choose from. What are most of you running on 10s with reasonable power?
I'm more swayed to the 3.1 as this will give a better cruising RPM. I'm looking at around 160bhp so would of thought it would pull of the line ok with the long ratio. I don't want to loose to much of the line though!
I've got an ST box so not far of clubman as follows...
2.583 1.711 1.250 1.000 Minispares (Clubman ratios CR/SC) C-STN39
2.544 1.731 1.258 1.000 Minispares (Abingdon ST ratios CR/SC) C-STN77
hazpalmer
Member #: 9038
Carlisle, Cumbria
I think most people on 10's tend to go with the 2.9 because you've got the power to pull the taller gearing. In mine iv got a s/c c/r ratio clubman set i got off Oli with a 2.9 in it.
Go with the 3.1. I've got a 3.2 in mine on tens and is good.
welshdan
Member #: 1111
s wales
running 13s here, tran x close ratio gearset. 3.1 FD, its ideal for road, hard work to get off the line but flies once its going. running 180 bhp, pulls right up to 8k and beyond. any lower and I would spend more time changing gears that anything else.
did run a 2.9 with 13s, same gearset, much less power, seemed to kill the revs ie had to change up at 5k.
slater
Member #: 1291
Suffolk / Birmingham
Your car is NA tho isn't it? So you will want it to rev? Tbh i don't think its a question we can answer. It's a compromise.
alaskanow0
Member #: 8466
Mansfield
3.1FD in my Clubman with SCCR clubman Gearset, 712kg. Works really well. The heavy RTS really seems to help pulling off. My Red turbo had 3.1FD and the ST Gearset, it was a nightmare with the X LITE lightweight clutch.
Edited by alaskanow0 on 13th Jan, 2015.
jonny f
Member #: 9894
Dorking
Cheers for all the answers guys, I'll go with the 3.1.
Slater, it's N/A at the moment but I'm building a turbo motor. It's actually got a 3.1 in it and pulls that easy, but it's a longer ratio standard gearbox.
jonny f
Member #: 9894
Dorking
Oh and I'll be building an RTS so that should help :).
Cheers again.
I'm using a 3.44:1
I really like it, unless driving on the motorway, when I absolutely hate it.
There is a turbo gear set I saw once or twice with a short first for use with a long fd iirc it was close 3.44 first with a 3.1fd
That was a quaife gear set Paul. Not available anymore unless you get swifty to commission about ten sets!
SadamPl
Member #: 10924
Wroclaw/Poland
I once did a trip from where I live to Bodensee area (wheere Germany, Austria, Switzerland borders meet) some 800km or so. It was a 998 Cooper engine with close ratio box and 3,44 diff, 10inch wheels.
It was a great fun to put 4th gear at around 50kph and watch the car pull whether it was flat or even up the hill, but... I spend enough time in the car to be 100% sure that every 15min trip on the highway will cause a huge headache :) Therefore I vote 3,1 as well :)
Made in Poland build thread:
http://www.turbominis.co.uk/forums/index.p...tid=570363&fr=0
D4VE
Member #: 10749
lowestoft suffolk
2.9 in mine and its the best allrounder that ive ever had
Nothing gets past Dave lol
jonny f
Member #: 9894
Dorking
You on one of the above gearsets Dave?
D4VE
Member #: 10749
lowestoft suffolk
1st one i believe clubman sccr
alaskanow0
Member #: 8466
Mansfield
I found the 2.9FD brilliant with my helical Gearset, but fitted the 3.1 with the SCCR box as I was concerned about driving in traffic and having to slip the clutch to pull away.
D4VE
Member #: 10749
lowestoft suffolk
I do have to do the lil tap of rev - double clutch pull away... but it was the same on shanes jet black when i drove that years ago... im used to it n once its bit its gone!
