| Home > Help Needed / General Tech Chat > HT Lead ends for coil pack on mega jolt set up | |||||||
186 Posts Member #: 538 Advanced Member Frimley, Surrey |
13th Jan, 2015 at 06:13:14pm
Hi Lads
13th Jan, 2015 at 06:31:21pm
I bought some fiesta plug leads and chopped them to length, and then fitted 90 deg spark plug ends. I used a coax crimping tool to make the ends off. Works well, and cheap enough. http://www.ebay.co.uk/itm/like/32139942071...f13=80&ff14=108 |
13th Jan, 2015 at 06:38:48pm
I went halfords and opend all the packets until I found the ones I wanted. Fiesta ones iirc. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
13th Jan, 2015 at 08:18:11pm
How long are the fiesta ones? I wanted them to be in the blue HT lead so that's what I have bought. Seems a bit extreme to buy a set of new leads just to take the ends off!
![]() 2975 Posts Member #: 10749 Post Whore lowestoft suffolk |
13th Jan, 2015 at 08:23:34pm
Mine are rather long.. goes to drivers side of fusebox On 24th Oct, 2015 jonny f said:
Nothing gets past Dave lol NOTHING GETS PAST ME!!
1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
13th Jan, 2015 at 08:39:49pm
If it's the early Ford coilpack with the hollow female connector and strange clips around the HT cable ends, I doubt you will get a connector by itself.
12 Posts Member #: 11042 Member Lanark |
13th Jan, 2015 at 08:39:53pm
I have a 3 fiesta leads as one was faulty so changed set and kept for spares. You can have the if you like. But they only cost about 25 quid for full set. |
13th Jan, 2015 at 08:56:35pm
I went to halfords found what I needed got 2 packs for the price of one on the trade card then made a set up with the size i needed Edited by madmk1 on 13th Jan, 2015. I have started posting on Instagram also my name on there is turbomk1golf
133 Posts Member #: 476 Advanced Member The Black Countraaaaay |
15th Jan, 2015 at 11:39:58am
As a few others have already said go to Halfrauds and have a look. It's quite amusing when a member of staff is staring at you while you're opening all the boxes and measuring the leads Masturbation is not a crime its a hobby |
174 Posts Member #: 9128 Advanced Member |
15th Jan, 2015 at 09:50:30pm
You want a set for a ford fiesta 1.3 N-reg, these had the coil on the back of the block. |
