| Home > Help Needed / General Tech Chat > Na carb conversion to turbo | |||||||
116 Posts Member #: 10945 Advanced Member scarborough/ northyorkshire |
13th Jan, 2015 at 11:52:42pm
I'm using a NA carb, I have rebuilt it using a full turbo rebuild kit. I need to pressurise the float chamber but carnt do the T,piece trick as don't have a pipe on the side of carb to link pipe from plenum, from searching on here if read I need to drill somthing to pressure float but carnt find any pics of where to drill, if anyone has any pics or info that would be great cheers |
14th Jan, 2015 at 04:30:36am
If you offer the plenum upto the carb and take note of what holes are not drilled it will become obvious
Yes i moved to the darkside |
14th Jan, 2015 at 09:08:36am
Cheers Brett il take it to bits again!:) |
