| Home > General Chat > Damp proofing a garage | |||||||
18th Jan, 2015 at 06:11:49pm
I know there has been a few posts over the years on this but could not find what i wanted.
18th Jan, 2015 at 06:20:25pm
I used KA tanking slurry on the outside of our garage and put in a french drain. Water would run through the garage in the pissing rain as the wall retains about 5-6ft of sand.
Edited by jonny f on 18th Jan, 2015. |
264 Posts Member #: 11029 Senior Member Crewe |
18th Jan, 2015 at 07:55:27pm
lol i had a concrete sectional that leaked quite badly replaced the roof with osb boards and felt 10 years ago it was great. smashed it down in nov waiting for the builder to fit the master bedroom on the top now !
Outside the box |
![]() 1751 Posts Member #: 10190 Post Whore belgium |
18th Jan, 2015 at 08:46:43pm
I done my previous garage walls coverd with cement that is used in basements? ( under the ground also used to store wine or hide death people ) the floor was then covered with a sort of tar but not the sticky kind. Should do the same with the new garage but its a bit to big for that. Also had a dehumidifier in there running 3 hours a night. you can do anything if you set your mind to it...
18th Jan, 2015 at 10:21:41pm
neil , is it worth doing the roof ,and some proper guttering ,and see if it all dries out ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
18th Jan, 2015 at 10:59:27pm
Id say with the roof done it may well dry out. Mine has gone all moldy this winter and ive just noticed a small leak. You'd be surprised what a little bit of water hanging around does. |
24 Posts Member #: 10973 Member |
18th Jan, 2015 at 11:56:06pm
theres a product you can't paint on like an industrial trade pva id assume might be worhlooking into i can't recall the name sorry |
![]() 489 Posts Member #: 9159 Senior Member Devon |
19th Jan, 2015 at 09:23:40pm
I used tanking slurry on mine, I got it from tool station, £20 for 20kg used x2 tubs, (single garage) just did it 4ft high from the floor up the walls and did the entire floor. Then painted the floor and walls afterwards.
20th Jan, 2015 at 12:14:32pm
Cat little boxes, the crystal type, I keep one under the mini, one under my tools and one under power equipments, works well for keeping moisture out that area, change it every 6 months.
20th Jan, 2015 at 12:42:49pm
I'd fix the roof first and see what that does. Tanking slurry may be an option if there isn't already a dpm installed but check the wearing capabilities of them. Some don't have a great resistance to impact and point loads |
21st Jan, 2015 at 09:37:59pm
Thanks chaps, i will see if the weather is good enough for fiberglassing tomorrow and go from there.
