| Home > Help Needed / General Tech Chat > New Cam Timing, | |||||||
6 Posts Member #: 657 Junior Member |
19th Aug, 2005 at 11:34:59pm
Picked up a Phase 2 Avonbar cam today, not a problem there, Although they had no timing discs, I have just ordered one. |
19th Aug, 2005 at 11:39:10pm
If you look carefully on both the cam and the crank pulley you will see a small mark, about 2 or 3mm diameter. These need to be lined up from the crank and cam with the chain installed in order to set the timing correctly.
19th Aug, 2005 at 11:51:26pm
On 19/08/2005 23:39:10 Tom Fenton said:
There is a guide on how to do this in the "How To" section of this site. I did look in there first of all before posting and couldn't see anything, I have the timing disc, however I do not have the dial test indicator, The Avonbar cam differs to the standard timing (Obviously).
Here is a picture of the old camshaft end, Are you referring to the ridge just before the thread starts of a smaller mark? |
19th Aug, 2005 at 11:55:21pm
No. Get the pulley and you will see what I mean.
20th Aug, 2005 at 12:00:09am
On 19/08/2005 23:55:21 Tom Fenton said:
No. Get the pulley and you will see what I mean. Mini Haynes manual also tells you how to do it. Basic timing setting is NO different to standard. If you have a vernier pulley you can set full lift where you want it, if not you are stuck with what the two gears and chain provide! Ha Ha Ha, That is potentially the best news I have heard all day, Thank you. I know exactly what your talking about,
20th Aug, 2005 at 12:08:04am
Some further reading-
20th Aug, 2005 at 12:12:27am
On 20/08/2005 00:08:04 Tom Fenton said:
Some further reading- http://www.turbominis.co.uk/forums/index.php?p=vt&tid=4769 I just saw it. Sorry
20th Aug, 2005 at 12:13:16am
No probs, good luck.
20th Aug, 2005 at 03:01:37pm
just like to add gal, tom.
Edited by BENROSS on 20th Aug, 2005.
23rd Aug, 2005 at 09:47:49pm
The Phase 2 cam achieves full lift at 110 Degrees.
23rd Aug, 2005 at 09:56:36pm
correct! gal
23rd Aug, 2005 at 10:09:28pm
In theory, yes, you are correct.
23rd Aug, 2005 at 10:09:45pm
On 23/08/2005 21:56:36 benross said:
correct! gal keep us posted on your progress I'm waiting for the rest of the parts to show up then I can finally start putting it all back together again.
24th Aug, 2005 at 08:41:41am
On 19/08/2005 23:34:59 Gal said:
Thing is I am used to working on Ford Engines and normally the TDC is indicated on the pulley, However on the mini engine there is no mark (Unless its the little hole that is on the pulley?). The hole on the pulley is a result of balancing, nothing more. For starters they're not in the same place (obviously) on different pulleys and if taken to a decent balancer, they're not in the correct place either :) On 13th Jul, 2012 Ben H said:
