Home > Help Needed / General Tech Chat > gremlins in a mpi again
D4VE
Member #: 10749
lowestoft suffolk
Hi guys my friend has a 2000 mini cooper sport mpi and one day it just suddenly got hot and boiled over... hes done a few things with no hope and the garage had a go and they are stumped... thought you guys would have more of an idea.. any ideas welcome please!! Heres what he sent me about what its had done so far.." New temperature sensor, expansion tank cap, rover approved wiring mod. Electric fan runs when disconnected and engine doesn't boil, it had a new thermostat before I had it, compression test ok. Still boils in expansion tank top and bottom hoses hot but top one hotter"
Edited by D4VE on 2nd Feb, 2015.
Nothing gets past Dave lol
Has the pump been checked?
welshdan
Member #: 1111
s wales
its boiling over with the fan running??
check the thermostat, a leakdown would be good also.
welshdan
Member #: 1111
s wales
also check for other leaks in the cooling system if I is venting to air it will allow the coolant to boil.
Blocked up rad?
Water pump.
1/ water pump impeller flopped off shaft, inside pump to block.
2/ possible goosed new thermostat ?
run without stat to prove it
3/head gasket goosed
D4VE
Member #: 10749
lowestoft suffolk
I have sent my friend whos mini it is the link to this page... i must say thankyou for all the ideas/suggestions/advice 👍
SadamPl
Member #: 10924
Wroclaw/Poland
+ 1 on the thermostat - either s**ty or fitted wrong way round
I'd try to swap the tank cap again. I had a new one that was bad out of the box once.
Made in Poland build thread:
http://www.turbominis.co.uk/forums/index.p...tid=570363&fr=0
D4VE
Member #: 10749
lowestoft suffolk
I know that the thermostat was done before he brought it, he brought it at the i.m.m and drove it home and done a run to the ace cafe all fine... but started this problem on a simple run into town.. he said he shall wip the waterpump off n see
Thermostat should sit above the sandwich plate. Youd be surprised how many people pit it back with it sat in the head.
Pressure cap leak is very common and causes boil over because system cannot achive pressure to prevent boiling at 104c when the fan kicks in
viz139
Member #: 9182
Mpi expansion bottle has a known weak spot where the hose goes on, check for crack.
D4VE
Member #: 10749
lowestoft suffolk
Doubt its thermostat as was ok for ages... ? And would it still boil over if had a crack in expansion bottle? I believe the fan does kick in.. seeing him tonight so will find out
PhilR
Member #: 10034
Birmingham
Yep, it will boil closer to 100 C if the system can't hold pressure well. Boiling point (of plain water) with a 7.5 PSI cap is roughly 112 C, and with a 15 PSI cap it's 121 C
Worth pulling the thermostat out to test in hot water. At the same time run the engine to see if it pumps water out the top of the head to see if that pump is still in one piece.
Edited by PhilR on 4th Feb, 2015.
