| Home > Help Needed / General Tech Chat > lowering compression | |||||||
133 Posts Member #: 476 Advanced Member The Black Countraaaaay |
5th Feb, 2015 at 11:59:23am
The other day my engine grenaded in spectacular fashion leaving pretty much everything fooked. Luckily I have a lovely turbo half engine spare to start on. The spare is a standard 1275 and I don't see the point in doing a rebore as the bores are in great condition as are all the other bits. I've also got a N/A head under the bed with 36 inlets and 31 exhausts. The big question is......is there enough meat on the standard turbo pistons to machine them slightly as the head that's sleeping under the bed was on an engine with 11.1 compression. The plan was to totally get rid of the beak in the head combustion chambers but if there's enough meat to machine the piston bowls a bit it saves me having to get too carried away on the head. Any advice appreciated. P.S I can do most of the work myself Masturbation is not a crime its a hobby |
5th Feb, 2015 at 12:20:27pm
Engine explosions are always awesome justification for building a more powerful one
Yes i moved to the darkside |
5th Feb, 2015 at 12:21:07pm
have a search; I'm pretty sure there is a thread with a section through a standard turbo piston that had been dished. |
5th Feb, 2015 at 01:04:01pm
I,m using dished standard MT pistons and a 28cc head and calculate I have 8.3:1.
5th Feb, 2015 at 01:26:17pm
if I were in your situation I would be looking at measuring the head cc. the chances are that it has been skimmed so wont be high.
5th Feb, 2015 at 03:37:59pm
the plan was to measure the head chambers at the weekend Dan as I can't remember how much I had skimmed off the head. If grinding out the 'beak' and slightly machining the pistons is possible I'll do that. I'll be sticking with 10psi boost and have the intercooler so don't need a huge dish in the pistons theoretically. I'll be working on the basis that the BK450 gasket will give me 3cc when the heads torqued down so once I know the chamber cc and piston to deck cc I'll know exactly where I stand Masturbation is not a crime its a hobby |
5th Feb, 2015 at 08:20:19pm
try to keep the beak |
5th Feb, 2015 at 09:03:29pm
I'd change the Pistons rather than wrecking the head On 7th Oct, 2010 5haneJ said:
