| Home > Help Needed / General Tech Chat > Heritage scuttle | |||||||
450 Posts Member #: 10396 Advanced Member Formerly mk2turbo Stoke-on-Trent |
9th Feb, 2015 at 12:44:45pm
How good are these panels normally? With the whole front end clamped on the bonnet touches the scuttle at both ends but with a gap in the middle, there's not enough curvature on the panel? Cheers |
9th Feb, 2015 at 12:54:34pm
Sounds like a mini! Might need to try some different bonnets. |
![]() 690 Posts Member #: 1851 Post Whore Woolavington, Zummerzet |
11th Feb, 2015 at 10:09:54am
The Heritage one's I've played with have been cock-on.
Metric is for people who can't do fractions. |
![]() 1751 Posts Member #: 10190 Post Whore belgium |
11th Feb, 2015 at 12:20:09pm
They indeed sometimes make a bit of a weird curve. Yet still much better fot than some other replicas i seen ... ( had a mate with a A-panel once wish was 9 mm shorter then original and so on.....) you can do anything if you set your mind to it...
11th Feb, 2015 at 10:20:00pm
I've got a heritage scuttle on mine. Make sure you are using a genuine bonnet. I tried what turned out to be a pattern one and fit was a headache |
11th Feb, 2015 at 10:27:15pm
Cheers for the comments, tried two other original bonnets...one was pretty much the same and the other was better but not perfect. Tried all three bonnets on my pickup and they were a good fit so it's either the scuttle is a bad pressing or the bulkhead hasn't got a big enough curvature. Need to take some more measurements |
