| Home > Help Needed / General Tech Chat > longevity of a supercharged engine.help needed | |||||||
136 Posts Member #: 1751 Advanced Member chichester/bognor |
20th Feb, 2015 at 01:09:36pm
Well I have built a supercharged engine for my car.its completely unrun atm.but I was chatting to someone and they said the expected longevity for a supercharged engine would only last 15k miles
On 30th Aug, 2008 Richie said:
too much my wife says "not that friggin site again" so i pull my pants back up and turn it over to TM. iam on pretty much every day as i lead a sad existance |
20th Feb, 2015 at 01:32:52pm
If it is a MED engine with the spec you list it is as good as it gets.
![]() 690 Posts Member #: 1851 Post Whore Woolavington, Zummerzet |
20th Feb, 2015 at 02:09:44pm
You don't mention which supercharger you're using, but suck-through with an Eaton will seriously reduce the life of the charger and possibly the engine.
Metric is for people who can't do fractions. |
20th Feb, 2015 at 03:30:13pm
Big difference between having to freshen up an engine with new bearings, rings and oil pump and binning the lot. I'd exect a freshen up after 20k not starting with a clean sheet of paper.
20th Feb, 2015 at 04:03:11pm
It's an injected Eaton charger injected at the Base of the charger sort of mid suck I guess.will be running a 12% reduced pulley.so I guess about 10-12 psi.
Edited by ashley_dude00 on 20th Feb, 2015.
20th Feb, 2015 at 06:37:05pm
I'm in the middle of pulling my supercharhed engine out. 30 miles on it so far On 11th Feb, 2015 robert said:
20th Feb, 2015 at 06:44:43pm
I ran my originsl sc12 on an engine built in 1969, that had 60k on the clock from 2007 until last year only used for shows and it was still going strong. But I never had any rotor coating come off. It's only used for fun, shows and some track days.
20th Feb, 2015 at 07:30:30pm
No reason why it would only last 15k if used as a normal daily. by that I mean not screwing the shit out of it at every opportunity and lots of steady driving.
![]() 1751 Posts Member #: 10190 Post Whore belgium |
20th Feb, 2015 at 08:38:24pm
if i was going this route i bought a last model one from a big bmw garage. theyy insured me the coating (black) on the latest models (4 or 5or... cant remember) is 100 % fuel proof. you can do anything if you set your mind to it...
20th Feb, 2015 at 08:57:10pm
I have that model with the hard'nd coating on it so hopefully.that won't be an issue.wontnbe used as a daily just a nice mini to go to shows in with a good load of power for a bit of fun and a bit of twists driving now and again.
20th Feb, 2015 at 10:19:04pm
On 20th Feb, 2015 tadge44 said:
If it is a MED engine with the spec you list it is as good as it gets. The life of an engine is so dependent on how it is used that to say it will only last 15000 miles is nonsense. If you rag it from cold every time you drive it and rev the nuts off it everywhere then it won,t last even 15000 miles. Driven with some respect,and set up properly on a rolling road, even allowing for moments of complete madness there is no reason why it should not last as long as any other engine. You don,t mention how much boost you will be using, which will be another factor, of course. Over boosting and risking detonation could grenade the engine in a few minutes. my thoughts exactley!
