Home > Help Needed / General Tech Chat > No boost
gtbuzzmini
Member #: 1195
Fort Worth, TX USA
Had the mini out for the first time in a good while and all had been in good working order before the time off. I hear the turbo (t3 metro) spooling up and dump valve is working when I let off, but boost gauge is never getting past 0. Am I right in thinking it may be a stuck wastegate and if so how do I further diagnose/fix the issue. Appreciate any help!
Matt
If the dump valve is working, then you have boost. I would start by testing the gauge and it's plumbing. Try pressurising the gauge's signal line with a foot pump.
gtbuzzmini
Member #: 1195
Fort Worth, TX USA
I am t'd off between the manifold and dump valve which I think is correct. Car definitely feels like it is getting boost and I have tried multiple gauges with same result. Stumped. Anyone else have any thoughts?
kink in the guage pipe ?
D4VE
Member #: 10749
lowestoft suffolk
Is it driving the same and just no guage reading or are you down on power to?
Nothing gets past Dave lol
Test gauge and line by blowing pressure into it where it's fitted at the manifold
Mini made all the right noises when it first went together but no boost. Eventually found out the line to the wastegate was kinked and holding it slightly open (can only assume it was creating a bit of a vacuum). Sorted that and all went fun!
There is no reason ever the w/g should see vacuum, and vacuum would pull it shut anyway.
gtbuzzmini
Member #: 1195
Fort Worth, TX USA
Does not seem to be lacking for power
Ok, to put it another way, there was no free flow of air to and from the wastegate actuator allowing it to hold open. The hose may have allowed movement in one direction like a one way valve.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
after i put my wiper motor back in being relocated inthe cab id pinched the boost vac line to the ecu and the gauge i was all why no reading on the gauge went for a real short drive hey boost hmm ding wiper motor a ha! goes for another drive gauges worked
silly mistakes rushing after dark just trying to get things done
