Home > Help Needed / General Tech Chat > Who can braze?
Chalkie
Member #: 9764
Northamptonshire.
I've broken my cylinder head. trying to remove the by pass tube due to it being rotted off
but this happened
so need it brazing up
thanks
Stephen
Better off arc welding it with a cast iron stick imo but instead of welding that bit back on Id build up the area and redrill it
Chalkie
Member #: 9764
Northamptonshire.
Thanks Paul I'm not fussed about having the bypass tube back in there i was gonna blank it off anyways
know anyone who could do that though?
I dont know anyone with an arc welder bur just look for a local welding shop
Cast iron is awful to weld, is the head anything special, if not it maybe easier to just find another.
Chalkie
Member #: 9764
Northamptonshire.
its a 12g202 head i got for swopping a hif44 carb so don't owe me nothing but its best sort of head i can lay hands on for my 998. expect a 12g295 but price is outrageous these days
I would just find another TBH. The 202 is just a 1098 head with slightly bigger inlet valves than the 998.
PhilR
Member #: 10034
Birmingham
Clean it back to shiny metal then MIG it up (normal mild steel wire). Weld for no more than 5 seconds at a time, then let it cool off just cold enough to touch (throw the broken piece away).
Don't use the pre-heat + slow cool method and don't braze either. Even if they work, you may warp the head requiring a reface.
Some cast irons may need more specific wire as Paul suggests, but I used the MIG and mild steel wire to block off the water holes in a 12G940, and repair a grinding mistake. Worked fine for me (and plenty more examples on the internet). Easy and nothing to lose by trying.
Edited by PhilR on 23rd Feb, 2015.
ally bronze rod and Tig?
is the head the same material as the block?
i know of a couple people who have welded the block with a regular mig
maybe even 3 people, didnt Simon ( madmk1) do this after breaking through making space for a turbo
You cant weld iron with steel so mig is out of the question. You can only weld iron with iron and provided its clean it welds very nicely, but as its nothing special Id replace it as Tom says
Chalkie
Member #: 9764
Northamptonshire.
would rather find a 295 but i may get this one fixed a mate has offered to weld it as Paul has said for beer tokens and keep it as a spare.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
is there enough to fit a tapered plug possibly an over size one?
if a std head id use a another one imo
PhilR
Member #: 10034
Birmingham
russellengineering.com.au said:
To summarise, the 295 head is possibly the easiest and cheapest way to get better performance out of a small bore motor. But for an ultimate performance small bore head, it turns out the 202 and std 998 head is the best to modify.
Chalkie, if you don't end up doing anything with it, pass it this way - I'll give you a few quid for it.
