Home > Help Needed / General Tech Chat > Drive shaft thread size
Custard
Member #: 8215
Rayleigh
Hello, can anyone tell me what the thread size of a disc driveshaft is for the castle nut.
Just want to run a die down it to clean it up as the ends abit scabby
Taaaa
Dave the Cake
slater
Member #: 1291
Suffolk / Birmingham
If your going to have a die that size you must surely have a set of thread gauges!
If you dont have a die then you might be better off with a thread file. A die that size is probably going to be more expensive than a brand new CV!
Custard
Member #: 8215
Rayleigh
I'll borrow a die from work with any luck :)
I guess I should just use a thread Gauge, but I'm at work and my stuffs at home so I'm being lazy!
Dave the Cake
Custard
Member #: 8215
Rayleigh
For some reason somewhere along the line I've managed to hit the driveshaft and its squashed the first couple of threads up so the nuts stiff going on. the threads fine where you torque it up so Im trying to avoid a new cv. I know they aren't too expensive but this cars cost me enough lol
Dave the Cake
file?
hacksaw?
Stick it in the lathe and machine the bruised bit off?
KLAS
Member #: 2380
Hamburg, Germany
IIRC it is 7/8" - 14 UNF
Custard
Member #: 8215
Rayleigh
Thank you klas!
Dave the Cake
Custard
Member #: 8215
Rayleigh
That worked a treat for future searchers info
Dave the Cake
Another thing to look at is investing in a set of thread files. I thought they were BS until I purchased a set of good quality old school ones.
They are perfect for when the end of the thread is chewed up and you can't get a die on there, or there isn't enough thread before the damage to keep the die square.
I also use them to lightly clean up threads, like removing old loctite, or other little marrs.
