| Home > Help Needed / General Tech Chat > Can you put an engine complete with gt17 turbo in from the top? | |||||||
43 Posts Member #: 9935 Member Leeds, UK |
25th Feb, 2015 at 07:58:00pm
I am putting my engine in from the top using a chain block mounted to the girder in the garage (same way I took it out) - will I be able to put a complete engine in with inlet/exhaust manifold and turbo on from the top? Or will I have to put the engine in first without the manifolds and turbo and assemble these after its in?
25th Feb, 2015 at 08:02:10pm
manifolds off,
25th Feb, 2015 at 08:17:47pm
ok cheers, what sort of access will there be to put on the oil drain and feed hoses? |
25th Feb, 2015 at 08:45:11pm
bolt it on when you can still tilt the engine forwards. On 7th Oct, 2010 5haneJ said:
25th Feb, 2015 at 09:41:00pm
thanks, cant wait to put the engine back in - been nearly 3 years since it was last in the mini! |
26th Feb, 2015 at 09:29:26am
well i put the subby in with the short block i had the head fully built up manifolds carb then bolted the head on from the top after subby was in suspension builts and engine bolted up worked a treat for me
![]() 1252 Posts Member #: 1656 Post Whore stoke-on-trent |
26th Feb, 2015 at 09:09:57pm
I put full t3 setup inc downpipe in my car from the top but i have a removable front end, took a bit of manhandling but its possible On 23rd Oct, 2009 sim_ou_nao said:
eu gosto de mamas = i like boobs |
336 Posts Member #: 9941 Senior Member Derby |
27th Feb, 2015 at 04:16:17pm
I have never built the turbo set up on the back of the engine in the car! It's always been left attached and lifted out of the top and my cars a round nose |
27th Feb, 2015 at 06:54:20pm
Is it a Metro cast manifold or Mirage type? I can drop in my engine with T2 on a Mirage manifold pretty easy. On 7th Nov, 2008 Nic said:
53 Posts Member #: 10528 Advanced Member Denmark |
28th Feb, 2015 at 08:44:12am
Mine also went in with manifolds on (a round nose).
28th Feb, 2015 at 10:48:50pm
managed to get it in but didn't have the manifolds attached. I am using a matty manifold. |
