| Home > Help Needed / General Tech Chat > Brake calipers oil chanel failure | |||||||
67 Posts Member #: 8956 Advanced Member Algarve/Portugal |
9th Mar, 2015 at 10:20:52pm
Bought some used minispares 7.5" alloy calipers some time ago, only to find out this weekend wend trying to bleed the brakes a airline crack from the oil feed, scratch the airline and a huge hole appears...
9th Mar, 2015 at 11:02:29pm
you may be able ? to drill and tap it and put a suitable metric grub screw in there with some high strength locktight in ? Edited by BENROSS on 9th Mar, 2015.
9th Mar, 2015 at 11:04:10pm
Replace it - It's too risky to attempt a repair.
Edited by PhilR on 9th Mar, 2015. |
9th Mar, 2015 at 11:05:18pm
you may well be right phil
9th Mar, 2015 at 11:17:22pm
Is that a hole in it too ?
![]() 112 Posts Member #: 10125 Advanced Member Zoetermeer, The Netherlands |
9th Mar, 2015 at 11:18:00pm
never ever compromise on safety !
9th Mar, 2015 at 11:51:13pm
I´ve tried grub screws on some bike brakes drilling and tapping and never made them to seal properly, using steel balls grub screws work sometimes.
Edited by R.Rodrigues on 9th Mar, 2015. |
336 Posts Member #: 9941 Senior Member Derby |
10th Mar, 2015 at 06:27:36am
Get it tig welded up imo |
10th Mar, 2015 at 06:27:38am
10th Mar, 2015 at 06:46:25am
Scrap. Disc has been rubbing it making it so thin it has cracked. All you will do with a TIG is melt the paper thin material that's left back.
10th Mar, 2015 at 08:26:16am
I'd agree with the general consensus. While some things can be repaired, brakes aren't something you want to risk. Given what has already happened, i don't think you can rule out any other future failure. Scrap them I'm afraid |
10th Mar, 2015 at 08:57:30am
fucked drive flanges? On 28th Aug, 2011 Kean said:
10th Mar, 2015 at 09:50:09am
Bin em! If something is worth doing, it's worth doing half of. |
10th Mar, 2015 at 11:01:41am
This a hell of a coincidence because over on another forum we have a discussion on re -sleeved brake parts and there have been two incidences if cracked cast iron brake cylinders. It was suggested (briefly !) that they could be repaired but, as on here, common sense prevailed.
10th Mar, 2015 at 11:11:36am
If it was just a small amount of wear that had opened up the oil way and absolutely no crack, I'd consider welding it up (depending on the scale and position of the damage).
Edited by PhilR on 10th Mar, 2015. |
10th Mar, 2015 at 02:41:04pm
Just pass my welding man this morning and he says to try to weld, there is no visible crack it must have open because its so thin, I should try to weld and do a blank spacer to put it on the press and do a pressure test, have to see if I have any gauge up to 1500psi or close, 1500psi should do the job i think...
10th Mar, 2015 at 03:37:31pm
By all means endanger your own life, but if your repair should fail and you knock down a bunch of nuns a young mother, her toddler and a baby in arms on your head be it! Edited by John on 10th Mar, 2015. If something is worth doing, it's worth doing half of. |
10th Mar, 2015 at 04:42:01pm
I'm confused, as your first post suggests it has a "hairline crack", but now you say there's no crack.
10th Mar, 2015 at 05:20:03pm
Just don,t do it ! |
126 Posts Member #: 10212 Advanced Member Sleaford Lincolnshire |
10th Mar, 2015 at 07:03:41pm
Don't even consider using these now they are scrap |
10th Mar, 2015 at 07:08:15pm
second pic looks like its cracked to me from the oil feed hole out towards the worn hole
Edited by Brett on 10th Mar, 2015. Yes i moved to the darkside |
10th Mar, 2015 at 08:37:22pm
Sorry for my English, wend things start to be more technical this is my best.
Edited by R.Rodrigues on 10th Mar, 2015. |
1713 Posts Member #: 8480 MS Paint flat cap champion & Morris Ital Lover From Sheffield now live in York tha noz |
10th Mar, 2015 at 10:14:14pm
the only thing they can be used as on a car now is as a fucking wheel chock, they are scrap my friend. On 18th Oct, 2013 apbellamy said:
I am feeling particularly BACish today. On 5th Oct, 2014 Shauna said:
What that's crazy, you go commando hahaha! How heavy is your helmet ? The Morris Ital assassin! |
10th Mar, 2015 at 10:20:42pm
just some last photos from how they look after the cleaning earlier today,
10th Mar, 2015 at 11:38:23pm
It looks like you've used a steel wire wheel? This will just move the aluminium around and hide any cracks if there are any.
