Home > Help Needed / General Tech Chat > Swapping rubber cv joints for pot joints
longy
Member #: 2727
Bicester
Can i directly swap rubber crucifix inner cv joints for pot joints? I have a full cooper s brake kit i want to fit, but will the diff output shafts take pot joint?
1972 998 TURBO SLEEPER
Drive shafts are different, so you would need to swap them for pot joint shafts.
longy
Member #: 2727
Bicester
Ive got drive shafts from an 87 mini, what im not sure of is will the later pot type inner joints fit the diff. is the spline on the rubber joint type the same as the pot joints
I think the dif needs swaped mate.
longy
Member #: 2727
Bicester
thought that might be the case, cheers simon
Deffo need to swap the driveshafts and at very least the diff output shafts, or the whole diff for simplicity. Either way the engine will have to come out
I've got a fair few pot joint output shafts if you need some.
Oh hang on, you'll also need the diff side covers for pot joints too!
longy
Member #: 2727
Bicester
Thanks for the help guys,
Ive got an A+ 998 to drop in, so ill just do the lot in one hit.
Alex
Member #: 1851
Woolavington, Zummerzet
The diff side covers are the same for rubber couplings and pot joints, they are only different with Hardy Spicers.
