Home > Help Needed / General Tech Chat > Fuel filter
upmonkey
Member #: 46
Just Registered!
Any body know where I can obtain, at a reasonable cost, a fuel filter with 10mm tails, to fit between the tank and the pump on my turbo. A filter meant for another car would do if any body has any ideas please let me know, cheers James *smiley*
SumpNut
Member #: 28
champion L 101
It costs a couple of pounds from TMC. Its a disposeable plastic filter.
When i get these i run a drill bit into the tails to make the Internal diameter a bit bigger.
upmonkey
Member #: 46
Just Registered!
Cheers off to Halfords for me then.
billydude
Member #: 48
Leicester
has anyone tried the nissan bluebird fuel filter ?
it is quite big but not huge like an injection filter but steel cased rather than the thin plastic one ?
I am not keen of the plastic one personaly although that's what's on my mini *indifferent*
billydude
Member #: 48
Leicester
here's the one I mean
http://volcano.photobucket.com/albums/v11/...dude/filter.jpg
the only downside is it cost's ?7 *blush*
but it's gotta be worth 7 quid to loose that plastic thing *wink*
Edited by billydude on 22nd Jan, 2004.
billydude
Member #: 48
Leicester
Hmm when I edited the post above it shoved this post down the page *frown*
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
are they 10mm or 8mm connections?
alex
AlexF
billydude
Member #: 48
Leicester
the od is about 8mm
